Question about Sony Playstation 3 (PS3) Console
My hdmi cable is broke
The end of it has come off i need to no how to put it back on any ideas
  • 77 Answers
You will have to buy a new one. If you try to re-solder it yourself, you will get the resistances all out of whack, which leads to not working or a bad picture.
Posted on Feb 20, 2009
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
Panasonic thp54s10a
SOOOOOOOO simple!
All you need to do is get an HDMI cable, plug one end of the HDMI cable into the HDMI output of the device you want to connect, then plug the other end of the HDMI cable into any of the three HDMI inputs on the back of your set! THAT'S ALL!
Once you have done this, turn on the television and your device, switch the input of your television to the appropriate HDMI input (using your remote control), and VOILA! The HDMI cable carries both picture and sound, so you're DONE!
May 21, 2014 | Sony Televison & Video
Satellite/Cable Coax "DTV/TV" in-port broke
Replacing connectors on televisions can be a pricy endeavor. If you can't afford to bring it into a service shop, you may have luck by switching to a different type of connector. If your Satellite or Cable receiver has an HDMI output, your best bet would be to buy an HDMI cable and hook that up instead - the quality would actually be better than coax. Failing that, depending on what kinds of outputs your sat/cable receiver has, you could also go with (in order of preference) component video (a cable with five ends, red/green/blue, plus two for audio), s-video (a round metal connector with four pins in the middle), or composite video (similar to a component video cable, but only three ends - red, white, and yellow).
Any of the above cables (including the HDMI) can usually be found at your local big box electronics retailer for under $30.
May 02, 2011 | Televison & Video
My ps3 turns on but the screen is blank i have tried another hdmi cable and its the same is it broke
It depends, did you try to use it at a friends house or anytime using composite cables, maybe some how it was put on composite, which means that when you try to hook it up on hdmi it wont work, because in the settings it isn't on hdmi automatic or hdmi at all, and is on composite. If you have composite i would try that, then put tv on the right channel, and if it works, you just have to set it back to hdmi only or automatic, and hook back up by hdmi and try that, it happen's, if that doesn't work then it could be a further issue. But i would try that first.
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
Great picture but suddenly no sound over HDMI cable
try replacing hdmi cable. if that doesn't work you have something in the amplifier curcuit bad
May 15, 2010 | Televison & Video
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Having trouble playing my Ps3 on a non HD tv after already using it on a HD tv
Hey bro try going down to circuit city, best buy and get the HDMI cord that converts to a Component cable on the opposite end. You can do this as long as the back of the non H/D tv has the Component Inputs on the back of the TV. If that does not work get the HDMI cable that converts on the opposite end to a S Video signal and connect that end to the S Video input on the back of your tv. I have seen these cables at circuit city in the playstation section. Again on one end of the cable it has your HDMI input to connect to your ps3 and on the opposite end of the cable it has the S video plug to run to the back of your tv and plug it into the S Video input. Same thing can be said for the HDMI on one end of the cable and the Component cables on the opposite end to run to the back of your tv. This will work if you find those cables. Good Luck.
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
When hdmi cable is plugged in bluray player stops
Since it was stretched check the ontacts on the acutal HDMI connector on the tv and the bd player a pin bent or touching another pin will cause a vast amount of issues
Mar 29, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Sony Playstation 3 (PS3) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
