I am receiving "E" symbal in my phone and i am charged for the same. I have tried by typing *#4777*8665# to deactivate the same, but still the "E" symbal is coming in my phone.How to remove the "E" symbal from my phone?
There is a way to reset your phone and reflash your firmware with flashloader 7.7.xA
turn off your phone and connect to pc with a microusb cable and press VOLUME DOWN+LOCK combo while you connect your phone.. install driver and flash loader software..
press SET MODEL button select c3300_LIBRE_setting_v2.mdl and select application binary c3300KJP.ptt
select c3300KOJPJl1.csc
start reflashing and reconnect using the VOLUME DOWN+LOCK combo that you used in earlier step
SOURCE: My teenage son accidentally washed
Unfortunately, it's done. Once something like that happens, it is very unlikely that it will work properly after that. Especially given what it is showing. Water and electronics don't work too well together.
In the future, if a phone gets wet immediately take the battery out. Put it in a tupper-ware bowel of uncooked white rice for about 5-7 days, then pop the battery back in. The uncooked rice will draw the moisture from the phone. However, after fulling being washed, it is most likely done.
Sorry,
Simon.
