Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Convergence circuit Need to know how involved a convergence repair kit is to use. Is there any soldering involved or is it a matter of just swapping parts. I have a 53" Panasonic rear projection LCD HDTV. When you turn it on it immediately goes out and the LED code light on the front blinks 3 times, pauses then blinks 3 times again. After doing a little research, I discovered it was probably the convergence circuit and can order a repair kit online with instructions, but would like to know ahead of time what tools I will need and how difficult it would be to repair myself.
    President:
  • 2,976 Answers
There is no way to tell what will be needed until you see what you ordered. If you get a plug in board, no problem. If you get a bunch of components, obviously there will be some work involved. CAUTION-THERE ARE DEADLY VOLTAGES INSIDE TELEVISIONS, EVEN WHEN NOT PLUGGED IN.
Posted on Feb 20, 2009
How do i fix this dip line its model 57 uwx 20 b
Look like RG convergence is out , but it's hard to tell from the pic
if you can't correct it with the set up in " convergence " on the setup menu , then your Convergence chips are failing
if you handy with a screw driver and a soldering iron you can swap out the chip yourself since it's not worth taking to a repair shop
cost for the chips 65.00 -70 , you can get cheaper if you shop around
youtube
http://www.tvrepairkits.com/xcart/hitachi-57uwx20b-convergence-repair-kit.html
buy part
Feb 24, 2016 | Televison & Video
My tv has begun showing a red shadow behind the pictures as well as letters, i have gone into the converge settings to resolve but cant figure it out
joeclaudiaag,
When the convergence will not adjust after you know you have set them correctly using your TV's convergence adjustment, your convergence board went bad. You can either repair it yourself with kits sold online (links below) but unless you know how to solder very well, opt for a repair guy. Your model will cost between $350 and $450 if you hire someone.
http://www.tvrepairkits.com/xcart/product.php?productid=20095&cat=0&page=1
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp-14g-43uwx10b61uwx10b-convergence-repair-kit/cName/convergence-repair-kits
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp15-convergence-upgrade-kit/cName/convergence-repair-kits
If you like to tinker but not dwell into the soldering world, try finding the same model for free or dirt cheap on a web site like www.craigslist.org that still works but like where a kid jumped into the screen!, and swap out the board.
Good Luck! Please rate this answer if I was able to help.
Mar 27, 2011 | Panasonic PT-56WX53 53" Rear Projection...
Colors converge will not adjust. What can be done?
Xpertis,
Good Luck!
-Chris
Sep 07, 2010 | Hitachi 57F500 57" Rear Projection...
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Convergence sony kp-57ws510
Convergence are daed.Have tools,lilke soldering iron,solders,solder wicks? Must know how to solders?Must repalaced 2 STK convergence ICS,some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 31, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the partstore.com with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
My screen image is concave, like a funhouse mirror. The image is distorted at the top and bottom of the screen. Any suggestions?
it is called pincushion circuit. either the diode went bad, the capacitors, or just maybe a simple solderond the bad connections.
Nov 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red and blue shadows appeared tonight on screen. Flash Focus and Convergence controls don't fix it.
Yes this is a failure of the convergence ic's it is a common sony big screen failure. I have written an article on how to fix this but it is involved and somewhat complex repair. A repair shop will typically charge around 300 for this repair. Here is my article:
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Oct 10, 2009 | Televison & Video
JVC AV-56WP30 has red onlines in picture (maybe red bulb ?)
This is a 2002 model----if picture looks 3d it has a convergence problem---if you go into the customer menu with the original remote select convergence and see if it will adjust----IF the answer is no, let me know and I can tell you what is involved to repair this problem.
SD TECH
Sep 30, 2009 | JVC AV-56WP30 56" Rear Projection...
The picture separates into the blue and red images. is this worth repairing? can I repair it myself?
Yes you can repair it yourself if you know how to unsolder and solder IC's
The two large Ic's in your convergence Circuit has failed. You will need to replace both of them to return to normal viewing, Also the unit may need a convergence alignment after repair to insure picture quality.
Your tv's menu should have a user convergence alignment option in the setup option, but for factory quality have a technician do a factory mode alignment. Replaced both IC's with part#'s STK-392-120
Hope this helps you:
Please leave comment for futher assistance.
Thanks Lavell
Sep 28, 2009 | JVC AV-48WP30 48" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
