Question about Hitachi 36UX01S 36" TV
Need info wont turn on
It started with a line across screen so i pulled it a part and soder the vert chip now when i plug it in you can here that it wants too turn on but dosent will the tv not come on if the vert chip is no good if i put too much heat on the chip could this cause the set not to too turn on so if i pulled the vert chip out of the set should it still come on or not ?i have not tryed yet
thanks
  • 39 Answers
The set will not operate with out proper vertical signal/deflection. you may have bridged pins together when resoldering. use a 25w or 35w soldering iron so as not to lift copper traces from pc board. always use solder wick to remove old solder and DO NOT keep on pad to long. mch
Posted on Feb 20, 2009
I have a Mitsubishi VS-5077 the screen has gone black, it started out with the darker colors going green, I was having to boost the britenees, than a line would flash vert. across the screen, now no...
You definitely have bad solder grounds. I have repaired a few of these. You will need a TV tech pull the boards out and resolder them. The worst board would be the one on the left [signal board, has rca jacks. rf connector]. And they may as well solder the second board. You will have a restored TV when completed. Thanks for asking and show a few hands of support!
Oct 10, 2010 | Mitsubishi VS-5077/78 TV
Hi i have a sony PFM42X1 has vertical lines over entire screen, on turn on. has a horizontal line across the middle of the screen. the colour is mixed pink,yellow and green. you can see the ghosting of...
I seen 2 post with same problum diffrent explations, I have the same TV with the same problem. I am sorry that all the answers are so silly and basic. I just open up mine to check all the compositors to see if their are any Bulging or to see if anything looks damage. I will pull the Power supply and start checking the compositors. and let you know. I will look in other places first to see if I can get some REAL Answers. Poco Zocko Actor
Oct 02, 2010 | Sony PFM-42X1 Plasma TV
I have a HL-R5067W Dlp. Turned it on and have verticle black lines. Eight lines then 1 1/2" space then Eight lines repeated across complete screen.
It sounds that dlp chip got defective and need to be replaced to fix the lines issue. Local tv repairman will help you to get it replaced if you do not have experience of tv repair.
Hope this info will help you.
Thanks.
Jul 07, 2010 | Televison & Video
Lines across the screen
are they all the time or just when watching broadcast or a dvd. are the horizontal or vertical?
May 07, 2010 | Philips 42PF9630A 42 in. Plasma Television
1989 Cutlass wont start
the filter on fuel pump might be clogged as well or fuel pump needs replaced
Oct 01, 2009 | 1989 Oldsmobile Cutlass Ciera
The TV has a thin horizontal line across the screen. Sometimes the line has color and sometimes the line is white. Everything else seems to be working (i.e. sound, channel changing, game hookups)....
you have a vertical output problem,take something insulated and prod around board and see if pix starts to flutter,then you could have a "cold-solder" joint,otherwise its more than likely a capacitor between the vert driver circuit and the vert output circuitry,
Sep 12, 2009 | Televison & Video
Convergence problem
I can't imagine how you would have enough electrical contact on the STK110s without soldering them in place, so I would think you need to solder them before testing further. Running the TV without them soldered in place and properly heat-sinked could cause additional damage to the TV and/or other components.
Aug 02, 2008 | Panasonic PT-53TW53 53" Rear Projection...
SAMSUNG VERTICAL PROBLEM , BUT CHIPS ARE GOOD
you have some open resistors in the convergence circuits.
May 08, 2008 | Samsung HCL4715W 47" Rear Projection...
Vert deflection problem
You are correct about having a dry or leaky capacitor that is causing those lines to show on the top of the screen.
Check the caps with low capacitance like 1uf, 10uf, 47uf, etc.
No quicker fix for this one until you change the capacitors.
Hope this helps.
Mar 14, 2008 | Philips 32PT6441/37 32" TV
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
Hitachi 36UX01S 36" TV Logo
136 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
