Question about Sewing Machines
Manual for a Juki ddl-555-4 industrial sewing machine
We are an ambulance manufacture that has had your units for at least 5 years but the mauals have come up missing. I have been here for over a year and they were not being used then. So please, you have an maual for this unit.
Lisa Miles
Custom Coach International
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
How can I use the hm-7302 buttonhole foot on my DDL-555 Juki sewing machine
I believe that you are trying to use a foot from a home machine on an industrial machine. I don't really think its possible. If it is possible, you will need to find a snap on presser foot top that will be long enough for the industrial machine. See if you can find a "high shank" top for your foot. They come in two lengths: high shank and low shank. Low shank will NOT work on an industrial machine for sure.
I keep a home machine for making button holes. I bought a button hole maker for my Juki DDL 8700 but by the time I go through all the steps to change it (and the cost of the buttonhole maker was about $80!) it was easier to have an inexpensive used home machine in the closet to get out whenever I needed a buttonhole.
Good Luck!
Mar 10, 2016 | Juki Sewing Machines
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
What needle type is used for the juki ddl 555?
I use Organ needle in mine. You can find these at most dealer who carry industrial parts, including ebay.
May 11, 2010 | Juki DDL-8300
Juki DDL-5530 Sewing Machine Manual
go to login industrial sewing machine and you can doenload manual for juki machine
Aug 07, 2009 | Juki DNU-1541 Mechanical Sewing Machine
Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
1,061 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
