Question about Acer Aspire 5100 Notebook
Hi,when i switch my acer aspire 5100 on,it boots up but the monitor(screen)does not come on
  • adriann577 Feb 20, 2009
    Hi Viriiguy,simple question is there another switch that switches the monitor off while the pc is switched on???
  • 77 Answers
Is your monitor turned on? If so, then you likely have a dead monitor. Try plugging a different monitor into your computer and see if it works. Then get a new monitor.
Good Luck!
Posted on Feb 20, 2009
  • 1 more comment
  • Randy
    Randy Feb 20, 2009
    *edit* Sorry, did not notice it was a laptop.
    One sec for an updated comment.
  • Randy
    Randy Feb 20, 2009
    First take a flashlight and shine it on the sceen. When you do, do you see a picture? It kind of looks like a negative. If so either your CCFL Backlight or your inverter are bad.
    First step is buy a new inverter. They run about 50 dollars and are a cheap fix. It is located behind the LCD front cover, at the bottom of the LCD. If that does not fix it, you need a new LCD panel as the CCFL replacement is not a task for anyone less than an expert.
    If you do not see a ghosted image with the flashlight then you doto do the following..
    You need to hook an external monitor up to your laptop. Boot it up and switch the display to the monitor. I believe it is FN and F5 on that laptop.
    If you get a picture, you likely need a new LCD screen.
    If that does not give a picture on the external monitor, you need a new motherboard.
  • Randy
    Randy Feb 20, 2009
    I do not have an acer in front of me, but it will be one of the Function keys at the top plus the FN key.
    The Function key will have a picture of a monitor or two on it.
4 Suggested Answers
  • 29 Answers
SOURCE: acer aspire 5100 notebook kb and mouse doen't work on boot up
Try to remove ram memory and put it back after a while. Do it on removed battery.
Posted on Mar 23, 2009
SOURCE: graphics picture problem on my Acer aspire 5100
is the correct video driver installed?
Posted on Jul 19, 2009
  • 20 Answers
SOURCE: acer laptop aspire 5100 keyboard,all 3 USB ports,
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
Posted on Jan 03, 2010
Black screen
the Acer Aspire 5100 notebook has a VGA port which you can connect to any VGA monitor which will allow you to see what the laptop is trying to display allowing you to troubleshoot the issue.
Jan 19, 2014 | Acer Aspire 5100 Notebook
Acer aspire one ZG5....connected to another monitor pressed control key and F5. The other monitor starts to boot up windows, gets to a certain point and then shuts off connection from acer laptop, who's...
As by your description, your mainboard of the laptop is faulty as the unit fails to produce a good picture on both its own LCD and on a external LCD
May 25, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costly
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer aspire 5100-3583 boots, screen is on, but
Dec 07, 2017 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 notebook kb and mouse doen't work on boot up
Mar 22, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 black screen
pls check the RAM i think it is a RAM malfunction it has nothing to do with lcd if ur system does not bootup and u dont see any hard disk activity as loading OS files while the screen is OFF black then try changing RAM , or if u have 2 chips of RAM try one at a time in one slot that is the upper most or get another one to try with same specs
aslo try connecting the monitor out this will trouble shoot ur LCD screen and vga
pls let me know if i can help more , and rate me FIXYA if i fixed
Mar 09, 2009 | Acer Aspire 5100 Notebook
try to boot into safe mode, to do this restart the pc and as it boots hit F8 repeatedly, this will bring a sub menu up and choose safe mode, when in safe mode perform a system restore and take it back a week or so
I hope this hepls and please don't forget to rate us
Dec 11, 2008 | Acer Aspire 5100 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
