Question about Canon imageCLASS D760 All-In-One Laser Printer
Paper jams right before it exits copier
Canon Imageclass D761. The paper jams right before it can exit the copier. I pull out the toner drum and it appears there is a ''plate'' sticking up slightly and the paper stop against it. My guess is that this ''plate'' is supposed to be underneath something so the paper will pass right over it. Any solutions or comments?
  • THHMI Apr 18, 2009
    I have the same problem. Had it repaired ($150.00) and it happened again six weeks later. They now say something has to be replaced that costs over $400.00. Best to get a new one. Shopping for it now, but hoping for a different solution to this one as we liked it a lot.
    Scholar:
  • 121 Answers
If the plate looks solid, then it's probably right where it should be. It sounds like a sort of ramp that feeds the paper into the fuser.
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Posted on Aug 23, 2010
How do i fix a paper jam? Where the paper is completely stuck inside the paper and both ends barely show?
need to know what model machine it is and in what section is the paper jam occurring. have you made any change in paper type or size recently?
Mar 31, 2010 | Canon imageCLASS D761 Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Paper jam Cannon PC 1060
hello,remove all covers arond the exit area lift cart door, control panel screw ,slide left,remove glass.holes in top under glass and under control panel,slide top to left,look down into holes to see screws holding fuser in.three connectors slide out exit side ,carefully dissasemble fuser to remove jam.i replace at least one unit a week.do use sharp objects
Nov 03, 2009 | Canon imageCLASS D761 Copier
Paper jam in the fuser unit.
hi
first you must remove the side panel on fixing side and move the scanner unit to reveal a two hole at the top of the machine,total of 3 screw for fixing unit,and one of that screw in front side of fixing unit you must use small philips screw,and take care to remove the wire
Dec 13, 2008 | Canon imageCLASS D761 Copier
Paper jam
you have support of a roller feeder broken open the right door and see if the roller that you see is oin good position.try to glue the plastic support.
Nov 22, 2008 | Canon imageCLASS D761 Copier
Paper jamb
you need a copier tech to fix it the fuser unit has to be removed to get jam out i done a lot of them and when some people try as you have to remove the jam they do more damage
Aug 20, 2008 | Canon imageCLASS D761 Copier
Cannon image class d761 copier
Check under the toner cartridge for the jam.
If this help you, please rate me. Thanks, Patty
Dec 28, 2007 | Canon imageCLASS D761 Copier
Canon imageCLASS D761 Grayscale Copier
hi im jules_09.try checking the power supply board,trace the voltage output from the power board to the logic or main board.if the logic board is deffective there is an error that will indicate it
Dec 09, 2007 | Canon imageCLASS D761 Copier
Canon imageCLASS D760 All-In-One Laser Printer Logo
230 people viewed this question
old marine
old marine
