I want to know how to fix it. The steering wheel is very sensitive at highway speeds,the switch has no effect. Thanks. NormI want to know how to fix it. The steering wheel is very sensitive at highway speeds,the switch has no effect. Thanks. Norm
You can't post conmments that contain an email address.
Instructions1 See if the problem is as simple as a blown fuse. It is probably a blown fuse if the temperature controls on the dashboard seem to work correctly but have no effect on the air. The fuse box in a Lincoln Navigator is located by the brake on the left lower side of the steering wheel. Pry off the fuse panel cover and find the blown fuse. 2 Have a look at the control panel next, if the controls are not working at all. First disconnect the negative battery cable. Detach the shift lever cover, and then the electrical connector. Unscrew the screws holding the trim cover on the shift panel. Disengage the four clips to pull the trim panel off. 3 Unplug the electrical connectors, remove four more screws, open the audio unit cover the whole way, disengage the clips in each corner and remove the climate control panel. 4 Listen for the blower motor to be properly working while the engine is running with the air conditioning controls turned to high. Adjust them from low to high to make sure the blower motor noise increases and decrease accordingly. 5 Find the blower motor in a Lincoln Navigator underneath the passenger side lower trim panel. Push the carpet back. Unplug the electrical connection from the blower motor, remove four screws and pull the motor out. Thanks
The
flasher is located under the sterring wheel to the left, just over the
brake pedal, the flasher unit is a (commonly) round or cubic dollar size
piece.
Ford had a common problem that would cause the blinker operation to fail caused by a short circuit in the turn signal switch. The switch contact plate will come loose causing the blinkers to stay on or not work at all. To replace this switch remove the steering column cover (3 screws on the bottom facing upward). Once the steering column cover is off remove the two mounting screws that attach the switch to the column. When the switch is loose from the column remove the wiring harness connector and reconnect to the new switch. Remount the new switch with the mounting screws and re-attach the steering wheel column cover and recheck operation.
No. The steering wheel does not need to be removed to replace the dimmer switch. Remove the screws under steering column and remove the upper and lower panels.
The flasher is located under the sterring wheel to the left, just over the brake pedal, the flasher unit is a (commonly) round or cubic dollar size piece
if your asking where is the flasher relay for dir, look under the left side of your dash and steering wheel .if u hear the click at all u might trace that of its exact location
