Question about Dell All-in-One 968+ Wireless Network Card Bundle InkJet Printer
Black line down the middle of my copies
When I print, there is no black line. When I scan something or copy something, I get a black line down the middle. Any thoughts as to why this might be happening?
  • Anonymous Mar 10, 2009
    Dell 968 AIO has vertical line on copies, but only on copies of originals run through document feeder. Line does not appear on copies of originals placed on glass. No problem with fax, scan or print functions.
  • 77 Answers
It sounds like you have a dead spot in your imager.
Posted on Feb 20, 2009
2 Suggested Answers
  • 191 Answers
SOURCE: scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Posted on Sep 17, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
Scanning/copying problem (Lexmark 6500 series x6575)
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Dell All-in-One 968+ Wireless Network Card Bundle InkJet Printer Logo
619 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
