Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon MP530 not recognizing PGBK cartridge
Suddenly new black replacement cartridges are not working or recognized by printer. The lights are on (NOT blinking), print head cleaned and deep-cleaned, PC restarted, printer and USB were unplugged. Nozzle pattern doesn't print any PGBK lines.
Using rebuilt cartridges and not Canon, but haven't had trouble with them before.
  • 1 more comment
  • adventurer66 Feb 24, 2009
    I have the similar problem. I cleaned the printhead using rubbing alcohol, but it does not work. I guess it is time to call Canon customer service.
  • marklfleming Mar 16, 2009
    I've used both Canon and Staples and can't get mine to print. The printer dialog shows the cartridge is full, but nothing happens.
  • wcfrito May 21, 2009
    Same as reported. Other test patterns are perfect.
SOURCE: plugged nozzle
I took my nozzle to ink specialist and had it cleaned only cost $15.00 but still better than buying new one
Posted on Jun 19, 2008
  • 76 Answers
SOURCE: Nozzle Blockage in Canon MP530
i hope you dont mean a snooker/pool q tip??
i would say to replace the printhead, this can be found on google.
part number is: QY6-0059-000
Posted on Oct 21, 2008
solofixya
  • 34 Answers
SOURCE: bottom half of pgbk band doesn't print
First try doing a deep head cleaning or two; if that doesn't work, try removing the printhead and looking at the bottom of it to make sure there is nothing blocking the small ejection holes on printhead, reinstall the printhead, do the alignment again an that should do it, if not you may need a new printhead.
Posted on Nov 11, 2008
Gort007
  • 1187 Answers
SOURCE: MP530 PGBK not recognized
1. UNplug printer at outlet or power strip & wait a full minute.
2. Plug back in and check if ok now.
1. remove cartridge; look for "spit wad" stuck onto the cartridge or in the cartridge cavity in printer.
1. If of the above neither works; use a new cartridge, but don't discard old one.
Posted on Sep 01, 2009
komguy
  • 2306 Answers
SOURCE: the pgbk on the Nozzle Check Pattern doesn't print
It means you either need a new printhead, QY6-0061-000, or the purge assembly is worn out and not cleaning or priming the black properly. You can change the printhead but the purge assembly is a shop repair.
Posted on Nov 06, 2009
Testimonial: "thanks! I was leaning that way from what I had read online!"
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printer does not recognize cartridge which was good yesterday
Hi
Tough one here but try removing / replacing cartridge, failing that try new replacement as each cartridges have their own electronic chips. I assume you are using genuine canon carts.
Cheers cbacer
Aug 11, 2009 | Canon PIXMA iP90 Mobile Printer
PGIBK cartridge is not recognized in Canon PIXMA MP530
This may be appear to be a stupid question, but did you turn the printer off and then on again?
Aug 02, 2009 | Canon Pixma MP500 All-In-One InkJet...
Won't recognize the cartridge UO43 error
Do you have another cartridge you can try. This sounds like a defective cartridge. Thanks.
Apr 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
PM530 printer: PGBK cartridge not working. Just
Clean the feeder use Que tip With Alcohol only let it dry and clean the cartridge the same way replace the That should solve the problem, Also keep in mind if you are using a cartridge that is a refill The cartridge sometimes dry out Have that checked it might be bad other words plugged up. Good luck with it
Feb 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
PGBK cartridge on Canon MP530 won't stop flashing. I have replaced the cartridge with new but remains flashing and won't take a print command.
plz clean the cartridge and head contact point and try, if the problem persist then try with another set of ink
Jul 01, 2008 | Canon Office Equipment & Supplies
Printer wont recognize new or old cartridge
Use a Q-Tip and some clean water to clean the contacts behind the cartridge in the printer and on the cartridge itself. Then use a pencil with a clean eraser to polish the contacts. Be careful not to touch the part where the ink comes out of the cartridge.
Also, are you using Canon ink or third party?
Jan 09, 2008 | Canon PIXMA iP1600 Printer
Ink cartridge red light
need original canon ink cartridge not generic
Jan 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
152 people viewed this question
old marine
old marine
