Question about Watches
Automatic watch seconds hand stops at 8
I recently bought a watch, looks new has a 2892-2. Even after being on a winder or wearing it for a while it the seconds hand always stops at around the 8 mark, I have to tap it a couple of times for it to continue.
  • danielmmtz Feb 20, 2009
    The dial is flat, it would seem like it is a movement issue, when it get to the 8 mark it stops then if I tap it, it hesitates moves a couple of seconds, then I tap it again and it continues on 'til it comes back full circle...
    President:
  • 2,976 Answers
The 'dit' at the 8 is higher than it should be. Slightly lifting or unbending the tip of the second hand will correct the problem.
Posted on Feb 20, 2009
  • David Shaub Feb 20, 2009
    If it moves and then stops and moves again, I would suspect dirt inside. Check with a jeweler about having it cleaned.
Winder for automatic watch
When you wind it manually (forward or clockwise) it winds the mainspring. Only need to watch it 5 or 6 times if it's completely stopped you wearing it will do the rest. If you going to get a automatic winder get one that will wind in both directions. It will give a few revolutions clockwise and then we'll go reverse counterclockwise.
Hope this answers your questions thank you.
Jun 06, 2015 | Bulova Mens Marine Star - 98B209 Watches -...
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
My Cartier Roadster does not keep time in my watch winder, all other brands work except this one. Any idea why, should the winder be set at clockwise, counter-clockwise, or bi-directional.
I believe the Roadster uses the 2892 movement and as such should wind in either direction. Find a competent watchmaker and ask him/her to check the automatic winding mechanism for proper rotation. I am assuming this is a real Cartier.
Jan 17, 2011 | Cartier Roadster W62019X6 Wrist Watch
What is the purpose of the nodule labled "kinetec" just above the winder? why does tmahe second hand move twice as it sweeps?
mcdevito75 here, Kinetic means motion, energy, with watches I'm not sure, although it could mean your watch is a windup-----------OR!! if you watch is AUTOMATIC it could mean, any motion of the watch will wind it, or it could mean if you watch is automatic and stops, un-winds completely after say 30 hours you can wind it to get an initial start then wear your watch to keep it wound. In your travels visit a small watch repair shop in your area for more info.
Nov 19, 2010 | Watches
How do I start my Pulsar watch? The instructions said to swing it side to side for 30 seconds...that didn't work. Checked the battery and it's ok..even exchanged the watch but this one's the same...I...
If you're supposed to swing it, that means it's an automatic or kinetic watch and it charges it's battery using an internal winder that moves as the watch moves. Try wearing it for a while, being mindful of moving your hand, or if that doesn't work try using a watch winder. If none of that works it probably needs a new movement. Take it to your dealer to submit for warranty.
Dec 20, 2009 | Watches
Breitling watch winder rotations requirments
The watch should last 36 hours from fully wound. If your wearing the watch and using a watch winder and its still stopping, you have a problem with the mechanism. Get it serviced. (its probably just a clean and oil req'd)
Mar 13, 2009 | Breitling Chrono Cockpit 164-Pilot Wrist...
New automatic watch keeps stopping
You can wind this watch until it is snug. If it does not continue to run during normal wear then you should have the watch looked at. The swing weight or main spring maybe malfunctioning. If you can return it under warranty that would be best.
Jan 31, 2009 | Invicta Automatic Watch
Patek Phillipe replica watch starts & stops
Try to wind it up using crown (winder). If it has automatic winder it will wind itself up while you wearing it on wrist.
Dec 14, 2008 | Bulova Watch
Wrong time
Your watch is an automatic watch which means it winds itself as long as you are wearing it. If you don't wear it for several days it will stop working. To solve this situation buy an automatic watch winder to keep your watch in while you are not wearing it and it will keep the correct time.
Dec 28, 2007 | Rolex Daytona 116520 Wrist Watch
Watches Logo
114 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
