Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Dryer not drying clothes
Hi.  Seems like there's lots of great advice on this site, I'd be grateful for some.  My Hotpoint Aquarius WD64 doesn't seem to be drying clothes.  The drying part of the cycle runs, and draws cold water, but the clothes come out just as cold and wet as when they went in.  I guess it might be a heater element but I'm not sure where to find it or how accessible it is.  Any ideas or other possible causes?  Thanks!
  • 135 Answers
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Posted on Feb 20, 2009
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
How does the powder tray come out for cleaning on a Hotpoint aquarius WD64 washer dryer please ?
there is a tab in the mid section between the two sections for the softener. You need to push the tab down at the back you should feel it go down then gentle push in slightly then pull out.
Hopr this helps
Sep 05, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Thanks.
Nov 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Sep 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Dryer not working on aquarius wd 420
call him explain still not working if hes not willing to help tell him your going to turn him into states attorney general you can file complaint online his company will get black mark and will haft to answer to the state!!!!! check for restrictions on exhaust hose-if not call reputable company and send bad mechanic bill!!!!
Jun 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Drying problems with hotpoint wdl 540p washer dryer
As it is a new washer, your best course of action is to the Hotpoint web site.
www.hotpopint.co.uk
then click on : after sales, for product advice.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Washer dryer WD64 Not Heating Wash Water
hi pw82,
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
Jul 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd640 replacement motor brushes
machine has brushes but they usually last longer than 2 years (mine are still ok after 5 years.
if you get no drum rotation, then suspect the brushes and replace them if necessary
Jun 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
252 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
