FE 360 U
See page 11 of this manual.
SOURCE: Olympus FE-130
on the above image you can see how I solved this problem. I used the way discribed in solution #2. I first broke off the little box and then added the little copper wire contacting the piece of iron at its left. Now my camera works again.
SOURCE: how to connect my olympus fe-360 cam. to laptop as webcam
Unfortunately this camera is not capable to be used as a webcam. It is only to be connected to the computer when you want to download images from the memory card to the computer.
SOURCE: Write Protected. What does this mean?
no, there will be a small button on your memory card just 'slide' it the opposite side. its on protect mode.
Regards
SOURCE: can i use a sd memory card with my olympus fe 330
No this is not possible. Olympus is using the xD-Picture Card.
If you get an microSD to xD adapter (Olympus MASD-1 adapter) it is possible to use Micro SD Cards.
