Question about Cameras
D700 Shutter Problem
Every 3 pictures I take with the D700 the first 2 are clear no problem, the 3rd, half of the picture is clear the other half fades to black - this repeats every 3 pictures taken - any ideas as to the cause - Please note, the sensor is not being blocked, it is not a lighting issue - it is something in the camera, I just want to know what the possible causes are before I send it out for repair. Thank you in advance for any info you can provide.
    New Friend:
  • 4 Answers
Did you try to use a different
Posted on Jul 03, 2017
SOURCE: Horizontal lines
I have the same problem with my camera and it appears to be a well known problem with this camera and some others models beside of canon's: The problem appears to be caused by a defective CCD integrated in the camera. The CCD is not very resistant to various enviromental factors such as humidity and changes of temperature, causing the "porcelain" cover of the CCD "brake" and make a contact failure or something like that. The fact is that Canon, Sony and some other brands annouced CCD Repair "or" replacement programs totally free of charge to the cameras presenting this problem. To identify if this is your problem, your camera must show at least one of these symptoms: *The images in screen LCD present/display a very noticeable dye towards some color. *The screen is completely black. *The images are corrupted or distorted. *The images have horizontal lines or bands. *The images have vertical lines or bands. - The problem appears because the type of glue that was used in the manufacture on the part of Sony, is sensible to the heat and the humidity, causing that the sensor separates of its base and creating failures in the connectors of the CCD. In a publication made by Canon Asia they annouce: Affected products that exhibit this phenomenon will be repaired free of charge, regardless of the warranty status, if disconnection of the internal wiring of the CCD is confirmed. which means, that at least in these places, Canon will free repair the cameras affected by this problem after even expired the guarantee. I hope this information is useful for you. Please rate my solution. Anyway you can check these sites up (in spanish but try google translator):
Posted on Feb 05, 2007
SOURCE: My DSC-T1 Camera only takes barely visible pictures
Tried the solution... video works fine.... but photo is just completely white ???
Posted on Nov 01, 2008
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Posted on Apr 05, 2009
  • 300 Answers
SOURCE: Canon SD 1100 IS Display screen is black except for icons
The CCD is dead or the lens shutter doesn't open. You have to contact your local Canon service center.
Hope this helps!
Posted on Jul 29, 2009
  • 11967 Answers
SOURCE: Hi! When I try to review the pictures just taken
Try cleaning the contacts on the card.
Posted on Aug 30, 2009
Testimonial: "Thank You for your advice, I'm going to carefully clean those contacts!"
There must be something simple I am doing wrong. On a D700 body, I can't seem to trip the shutter in any aperture other than f16.
I have a Nikon D60, and it has numerous settings, including aperture and shutter priority, and others. It sounds like you have have it set in aperture mode, set for f/16. First try taking a picture in dimmer light, where it's not so bright. That should cause the shutter to open longer. The camera will adjust the shutter speed to take the best picture at f/16 if it's set for that.To adjust it to something other than f/16, on my camera, you use the thumb wheel on the back of the camera. Try changing that if it has a thumb wheel.
Next try it in Auto mode by rotating the dial on the top of the camera to the green setting and see if you get a batter picture.
If all else fails, consult the camera manual, if you have one.
Jul 13, 2011 | Nikon 85/1.4 AFD Nikkor Lens
How do I prevent constant blurred pictures when taking shots of kids in my family. It also takes at least 3 seconds from when I press shutter button to when camera takes picture..often too late to get...
You need to practice the correct shutter button technique. You need to press the shutter button half-way and wait for the focus to lock (it will beep) and then, when the moment is right, press the rest of the way for an instant picture with no "lag time".
Nov 12, 2010 | Sony Cyber-Shot DSC-P100 Digital Camera
How do you set the apeture on a Kodak Easyshare DX4530 camera?
1 In any Still mode, press the Menu button.
2 Press to highlight Exposure Compensation , then press the OK
3 Press to select the Exposure
Compensation setting.
 If pictures are too light, decrease the
 If pictures are too dark, increase the
4 Press the OK button to accept the change.
5 Press the Menu button to exit the menu.
6 Use the camera screen to frame your
subject. Press the Shutter button half-way
to set the focus, then continue pressing
completely down to take the picture.
This setting remains until you change the
Mode dial or turn off the camera.
here is the link for the manual if the details are not clear
Oct 03, 2010 | Kodak EasyShare DX4530 Digital Camera
Hello, Please help me I love my camera! The last 3 rolls of film I have taken only the last half of the roll come out the first part of the film is black I'm only getting half of the pictures I take. It's...
Most likely this is a shutter problem. If you are using flash and getting the half pictures, then make sure the flash is a canon compatible flash and the synch is set to 60th. If the problem is all the time including non-flash pictures, then the shutter will have to be repaired.
Mar 26, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
Nikon D700 viewfinder dark
It sounds as if there is a problem with aperture blades not fully opening.
A quick test...
With a known good lens on the camera, set it to shutter priority mode. Point the camera at a plain wall or ceiling, half press the shutter button and note the aperture reading suggested by the camera. (Play around with the shutter speed settings until you get something around about f11.)
If possible, switch to another good lens and do the same. (You will need to point the camera at the same wall or ceiling!) You should find that without altering any settings, you will get the same, or very similar, aperture reading as before.
Now try the suspect lens. If there is a a fault with the aperture, the camera will almost certainly suggest that a significantly different aperture setting is required.
Hope this helps!
Jun 20, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Takes photo but no picture ( Very slightly exposed)
Have you mounted the lens correctly? Try cleaning the contacts of both the body and the lens using an eraser. Take care that no dust falls into the body.
Mar 02, 2009 | NetBotz Cameras
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Canon EOS Rebel G - The picture is cut in half
I'm afraid this is almost certainly a shutter fault - the second curtain of the focal-plane shutter is getting stuck half-way across the film and therefore not shutting properly. The fact that the other half of each frame is OK makes me think that the second curtain is not sticking totally but just moving very slowly for half of its run, thus seriously overexposing that half of the film. This is a repair shop job - unless you want to try it yourself: it may be just some dirt stuck in the track the shutter curtain runs in, but a fair bit of skill is needed to get to it & clean it without damaging anything!
Sep 29, 2007 | Canon EOS Rebel G 35mm SLR Camera
Sony Cybershot W-5 mp ???
This has been a complaint on all of the Sony ''W'' series of cameras. They seem to do very well outdoors. Indoors is another matter. Under low light and flash conditions, the camera selects a slow shutter speed. This means you must hold the camera very steady or use a tripod. Here are some things to try: 1. Take a photo and instead of looking at the LCD, look at the body of the camera and your forefinger. Make sure that you are not causing the camera to dip downward on the right side with you press the shutter button. You should squeeze the shutter button between you forefinger and thumb. 2. Under low light and flash conditions always use the viewfinder instead of the LCD to frame your subjects. When holding the camera to your eye, make sure it is lightly touching your face. You head is steadier than two outstretched arms. If you can lean against a wall or something solid, do that too. 3. Under all conditions, use the two step shutter press. Press the shutter button half way down, then reframe your subject. Then press the shutter button the rest of the way down. That how the pros do it.
Sep 08, 2005 | Sony Cyber-Shot DSC-W5 Digital Camera
Shutter lag
we're talking milliseconds... my camera takes the picture when i press the trigger and sometimes its so fast that accidentally take the picture before i have focus lock (that my error not the cameras, i just get trigger happy sometimes)
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Cameras Logo
211 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
