Question about Whirlpool AWM6100 Front Load Washer
Affinity will not do final spin - Whirlpool AWM6100 Front Load Washer
  • 1 more comment
  • Anonymous Mar 29, 2009
    Won't do the final spin
  • Anonymous Apr 13, 2009
    affinity washer uns the cycle but the last 7 min. wont un spin cycle
    what plug
Sure you have fixed by now but i found that i released the plug and it was right again. also I find this happens when there are too many heavy wet towels in load.
Posted on Mar 22, 2009
Does not empty after final spin cycle I have checked the pump and hoses. The only thing I see may not be right a cylinder shape is in the boot at the outlet.
Hi Peter,
So I see that your Frigidaire Affinity washer is not draining completely after the final spin. I also see that you've checked the pump and hoses as well. There are a couple of other troubleshooting tips I might suggest.
1) Make sure the standpipe isn't too tall. Maximum standpipe height should be 8' (2.4 m).
2) Check the house drain pipes to see if they are clogged. If so, unclog the drain pipes. Contact plumber if necessary.
-Best Regards-
Jan 23, 2014 | Frigidaire Affinity ATF7000ES Front Load...
It will not do the final spin no matter how many cloths are in washer.
you have most likley have a program fault,,,there pricy to replace too?
Aug 08, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Jun 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Final Spin Cycle gets stuck at 1 minute
back tub bearing,,and spin surport,,defective,,,under warranty,,,call for service..onthejob
Dec 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity king-size capacity washer
my washer is not spinning the water out.what could be the problem?
Sep 23, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool AWM6100 Front Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
