Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
It seems that the plastic pump mechanism is not
The in counter soap dispenser is not working, no soap comes out. O unscrewed the bottle underneath the sink and took out the pump.
It seems that the plastic pump mechanism is not functioning. Help, is replacement the answer and where do I find it, or one? Thanks
  • keeley_carte Mar 14, 2009
    Different faucet type but same problem. Dispenser doesn't pump soap. It's not blocked - when removed, it will pump water from a cup.
  • Thomas F. Schneider May 11, 2010
    Soaking it in hot water may be your answer?.
Wanted to let you know I phoned Pfister at 1-800-7328238 and after speaking with customer service was told a new part to fix the problem would be sent to me at no charge for the part - but a $5.00 fee for the postage. I'm keeping my fingers crossed that this will corrected the no soap coming out issue...and
soon I will have a smile on my face once again when I go to use this!!
Posted on Mar 12, 2009
    Problem Solver:
  • 9 Answers
Unfortunately it is a very common problem with soap dispensers. First before you replace the dispenser, dillute a small amount of water mix with the soap in the bottle of the dispenser to see in fact if the pump is deffective. It could simply be that the soap is too thick for the pump to work properly. As to replace it, call the manufacture of the faucet which I presume came with the dispenser and very often they will stand by their products and send you one free of charge.
Posted on Feb 21, 2009
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
Purchased soap desp. model #RP47280SS with no directions. Left white ring with dispenser on counter and used rubber washer and plastic nut on bottom. I can't get the dispenser very tight to the...
bobj50-
The white washer goes underneath the counter (with the nut) and the rubber gasket on top of the counter under the dispenser head. You may find it easier to tighten the assembly with this configuration. As for filling the bottle, unfortunately it must be unscrewed from under the counter in order to refill it.
Hope this helps.
Regards,
DIYpro
May 17, 2011 | Delta & Soap Dispenser
Filled Blanco Alta soap dispenser from the top and have had issues with it ever since. The plastic straw repeatedly disconnects and even when it seems to be firmly inserted, the pump doesn't really work...
Get the plastic guts of the thing apart (again, I know). Soak in CLR, was thoroughly in warm water and dry. Squarely cut back the original squarely cut end of the tube about one-half inch with a razor knige. Reinstall the tube FULLY onto the base of the pump as far as it will go.
I no longer refill from the top. I now bite-the-bullet and crawl underneath in the cabinet, unscrew the bottle and refill.
Feb 21, 2011 | Blanco Alta Soap/Lotion Dispenser
Cannot open it to refill it how do i refill the
On my unit, I have to go under the sink and unscrew the plastic bottle, fill it and then screw it back on to the pump from underneath. You might want to try that.
Sep 15, 2010 | Blanco Alta Soap Dispenser Satin Nickel...
We have the single handle Pegasus 190 571 Brushed Nickel bathroom faucet. The soap dispenser got knocked and broke off and I cannot find a replacement for it.
The booklet that comes with that unit has the following part numbers: nut set (A66D111); soap dispenser sleeve (A665597); soap pump (A605230); soap dispenser nozzle (A66596). Those are all the parts (less plastic tube and soap reservoir bottle) for the dispenser- you probably only need one (the broken one!).
Jun 17, 2010 | Home
Re: soap dispenser of my K-R10430 Kohler 4-hole faucet. The small spout has started coming out of the body of the dispenser when dispensing detergent. Installation and homeowners guide don't show whether...
I'm not sure if it can be repaired or not, but lowes carries the same dispenser that came with faucet. To replace unscrew bottle from under counter now you remove plastic nut that holds the body to counter and install new one.
Sep 28, 2009 | Plumbing
Soap Dispenser leaks soap onto counter
maby minor crack between the the treds on the bottle that screws in to the pump or a crack in the bottom of the pump and you may not see it because the pressure of the pump isint in the bottle when you un screw it tot look at it
May 17, 2009 | Grohe Satin Nickel Soap Dispenser...
Bottle under Grohe soap dispenser leaks down to cabinet
Pull the dispenser out the top and have someone hold the trim above the counter while you tighen the bottle down below.
But the real problem is the retaiher nut which hold the dispenser in place is loose. Remove the bottle underneath ( it unthreads) and tighten the nut that you see just above the bottle. This can be a tight spot and you may need a basin wrench.
Please rate this response and Good Luck, Phil
Dec 27, 2008 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Dec 11, 2008 | Grohe Satin Nickel Soap Dispenser...
How do I replace soap dispenser pump mechanism?
Our brand new Avalon model had this problem. It sure appears to be a design defect or defective part. After contacting customer support, they sent a replacement pump (the internal part, not the whole unit).
After removing the unit from your sink, holding the top pull firmly with constant pressure on the pump assembly. It will pop off, but you have to pull pretty hard.
I suggest running water through the top of your unit before putting the new pump assembly on it. Ours had black 'junk' inside even though it was brand new. The new unit just slides on in the reverse process of removing the old one.
Oct 30, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
1,051 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
