Question about Zephyr Kitchen Ranges
Zephyr Typhoon control panel replacement
I need to replace the control panel in my Zephyr Typhoon range hood. Zephyr has sent me replacement part but I cannot figure out how to access the hood to replace.
  • Anonymous Mar 26, 2014
    zephyr model zk5600as
Instruction to replace the control module for
ZFI, ZML, ZMI, ZVE, ZPA, ZNA
  1. Turn off the power to the unit at the circuit breaker
  2. Remove metal mesh filters
  3. Remove safety panels/grills which are secured by 4 screws, 1 on each corner
  4. Look up inside hood for a 2"x 2"x 6" white box on the back wall of the hood, near the bottom panel. Please refer to control module diagram for detailed information
  5. Remove four screws that attach the cover to the white protective box
  6. Remove the control module from the box
  7. Remove the wires and reconnect one at a time to new control module *** Note: The black/white a/c power wire requires screwdriver to loosen the 2 screws for removal of the wire.
  8. Replace control module
  9. Attach cover to box
  10. Turn on power to unit at the circuit breaker
  11. Test all functions of unit
  12. Install diffuser safety panels
  13. Install metal mesh filters
Posted on Jul 23, 2013
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
  • tscott1931 Sep 27, 2010
    Seems there is a real problem with the control panels on these models shorting out and frying both the circuit board and the plastic control panel after 2 to 4 years of service. It is obvious Zephyr should be doing more than just sending free parts but that discussion is for another time and place. Removing the cover panel is a snap (5 screws) but removing the plastic front control panel and circuit board seems to have an trick that is not at all obvious.
My Zephyr Typhoon Range Hood (AK2100) neither light nor fan work i can not find fuse box
There shouldn't be a fuse box on the range hood.
You'll have to check your main house circuitbreaker or fuse box.
Jul 22, 2016 | Zephyr Kitchen Ranges
Fan and lights blew off
check the fuse. (see post about control board.)
excerpt: ... the control board is in the front of the hood behind the speed & light power buttons. There is a 3/4" Buss fuse onboard that seems to pop on my hood every few months.
Mar 06, 2014 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr typhoon ak2136 stopped working
I have the same problem with my unit. Have contacted Zephyr support and hope they have answers.
Jan 04, 2012 | Zephyr Typhoon AK2136 Kitchen Hood
How do you change the bulb on Zephyr AK2100S ?
To replace the bulb you need to use a suction cup to grab the bulb then turn counter clock wise.
If you need the manual it is on the link below. Page 18
http://www.zephyronline.com/docs/brand_essentials/products/manuals/typhoona_manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Zephyr AK2100S Typhoon 30" Under-Cabinet...
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Kitchen Ranges Logo
1,390 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
