Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The agitator does't work on the Whirlpool Utimate II & this washer is about 7-8 years old
  • Whirlpool Master
  • 3,361 Answers
You must replace the agitator dogs. Pop the top cover of the agitator to access the 4 defective parts. They are pear shaped.
Tools required.
Posted on Feb 22, 2009
I have a Whirlpool Gold Utimate Care II washer (model # GSQ9364HQO [not sure if that last figure is a zero or O]; SN CJ 4931194]). The washing machine stops at the end of the wash cycle. I'm left with a...
no solution here but i have same model number and am recycling it. everything works but chassis is loose from use of over 10 years. let me know if yoiu want me to send you controllers, timers, etc.
ricracric@austin.rr.com
Oct 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
Oct 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator on Whirlpool Ultimate Care II won't agitate
you can replacethe gears taht cause the agittion called agitator dogs part number 80040, probly $20.. reomveth efabric softener( swift smack with thepalm of you hand) and then remove the agititor with a 7/16 screw down the center shaft. the agitator will "split to reveal the "dogs" fairly easy repair
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator not agitating
Replace agitator dogs, which should be available at your local appliance parts store for around $10. Replacement takes about 20 minutes (for a Whirlpool washer, at least.) Remove the center filter and you'll see a bolt (11 mm in the Whirlpool.) Remove the bolt, which you may be able to do with hand-turn socket wrench unless you have an extension for your ratchet. Removing the entire plastic agitator assembly is easy when tugging from below.
This next part may note be needed, but: Once you have the assembly out put it on the floor and stand on it. To remove the free moving part of the agitator, grab the fins and give it a good tug or two to free it from the lower assembly. It may take a bit of effort. Remove the inards, replace the four dogs, and reassemble.
It was *really* easy to do...and certainly a lot cheaper than having someone come out or, as we thought we were headed, to replace the washer.
For even better description: click here
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool 3 year old washer
sounds like a bad basket drive.i don't know why after only 3 years though
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator Dogs
Nothing is manufactured to last these days. What brand of dogs are you using ? FSP is the original brand and should be used. Also, check the inside of the agitator. Are the gear teeth in good shape ? It only take one bad tooth to destroy the dogs.
Dec 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal De
