Question about Apple iPod MA446LL/A MP3 Player
I charged my ipod and now it will not turn on
  • blueextc3221
    blueextc3221 May 11, 2010
    Have you pushed the RESET button??
  • 115 Answers
Resolution Make sure the Hold switch is off
  1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
  2. To turn the hold switch off, slide it until you no longer see the orange patch.
  3. Press any button to turn on iPod.
Posted on Feb 20, 2009
Ipod will not turn on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
How do you now that your ipod is chargeing. how do we turn it on
If you iPod is charging and is off the screen will display a battery with a lightning bolt. To turn the iPod on simple make sure the hold switch is set so you cannot see the red and press any button.
Feb 28, 2011 | Apple iPod nano
Ipod won't turn on!
Step 1: Try charging your iPod via USB to your computer. Wait for a few minutes and see if it is accepting a charge. (You might have forgotten to charge it)
Step 2: After a full charge, try using your iPod. If your iPod dies in less than 2 hours or so, your battery is weakening or is dying out. If this is the issue skip to Step 4
Step 3: If you cannot turn your iPod on even after those steps, then your iPod really is dead. Proceed to Step 4.
Step 4: You can do one of either three options from this point:
  1. If you bought your iPod less than a year ago, the Apple Store might replace your iPod for free on the spot as part of their warranty. OR
  2. Go to the Apple Store and ask for them to repair your iPod for a fee.
  3. Go to the Apple Store with your old iPod, and turn it in when you buy a new one - you will receive a 10% off for a new iPod.
Feb 16, 2011 | Apple iPod touch
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    My iPod shuffle will not charge
    If iPod shuffle won’t turn on or respond
    â If the status light blinks orange when you press a button, the iPod shuffle buttons are
    disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
    blinks green.
    â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
    battery may need to be recharged.
    â Turn iPod shuffle off, wait five seconds, and then turn it on again.
    â You may need to restore iPod shuffle software. See “Updating and Restoring
    iPod shuffle Software” on page 26.
    Jun 25, 2008 | Apple iPod shuffle MP3 Player
    Infitek shuffle ipod
    Greetings bernince24,
    Generally when an Ipod is charged, it is off and connected to a usb port with your computer. It simply draws power off the computer. It is all pretty intuitive, plug and play. Meaning the once you hook the ipod to whatever charging device you are using, it will charge on it own from there.
    I hope this helps.
    Dorothy
    Go Ahead. Use Us.
    Jun 24, 2008 | Apple iPod shuffle MP3 Player
    Ipod not turning on or charing with computer
    Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
    http://www.apple.com/support/ipod.five_rs/
    If that is not able to fix your problem, contact apple or your dealer for more assistance or repairs.
    If you need more assistance let me know. Good luck.
    Jan 31, 2008 | Apple iPod nano
    Apple iPod MA446LL/A MP3 Player Logo
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
