Question about Hotpoint RGB745 Gas Kitchen Range
I have a hotpoint RGB745 oven temp problem
I have a hotpoint RGB745. The oven reaches the set temp. Then the flame will go out and not come back on unless, the oven dial is turned to off and then back to the set temp. Then the cycle is repeted...heats up ok then out etc. The indicator light for reaching the set temp. will only go out if you reset the oven temp to off. The oven temperature is very erratic. It is too cold, or, mysteriously,heats up way beyond the set temperature.. I have paid $300 in repairservice and was told it was too expensive to fix. I don't believe theyreally figured out what the problem was. I can only control the oventemperature by watching it carefully every ten minutes and turning theconrol off and on.
Hotpoint Gas Stove RGB
  • Hotpoint Master
  • 3,361 Answers
Replace the oven temperature sensor.
Posted on Feb 21, 2009
Hotpoint oven will sometimes preheat to temp, sometimes not, when it does it will not stay hot enoughto cook the food...replaced control board...still dont work..checked thermostat, works fine. glo plug...
if it's glowing but not igniting the flame in less than 40 seconds you have a lazy ignitor,change it out.open the draw unser the oven door and on the left or right side of frame not the door you'll see a tag with the model and serial number,give your parts store the model number and they'll give you the correct ignitor
Sep 22, 2010 | Hotpoint RGB745 Gas Kitchen Range
How do u relight a pilot on a hotpoint model #RGB745WEH77WW
normally the pilot flame is in the back of the oven use long match watch for gass explosion may be small but be careful should be in the back middle of the oven.
Dec 12, 2009 | Hotpoint RGB745 Gas Kitchen Range
Takes too long for oven to heat up
Hhi, Is this a gas oven? If the ignitor is going bad, it will not open the gas valve as soon as it should.
Please let me know so I can assist you further.
Vic
Jun 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven temperature off
If you have a ohm meter you can ohm out the temp sensor. It has a harness that connects in the back. Unplug it and it should read around 1100 ohms at room temp. It sounds to me more like the ignitor itself. It has to draw so many amps to open up the gas valve. Check the sensor first. If it ohms out, change the ignitor. I think your problem will go away. Tenbears.
Dec 20, 2008 | Hotpoint RGB745 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Oct 23, 2008 | Hotpoint RGB745 Gas Kitchen Range
Soultion not viable
Any other posts have been blocked, so I don't know what you have been told or tried. Has the oven temp been OK until just recently? The range has not been moved or converted Nat gas to LP etc. recently? If yes to Q1 and no to Q2, I'd replace the oven sensor ( WB21X5301) and then reset control to +- 00. Sensor is the pencil shaped thing sticking out the back of the oven. Note: Your temp test method is not accurate enough to calibrate oven exactly. I take average temp after a minimum 3 on / off cycles using a digital calibrating oven thermometer to get them within 10 degrees of set temp.
Sep 01, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven
Press the function you want - say bake - the set the temperature by pressing the plus sign (+) to increase the temp to that which you desire then press start
Regards
Aug 25, 2008 | Hotpoint RGB745 Gas Kitchen Range
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Mar 09, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
645 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
