Question about Brother CS-8072 Computerized Sewing Machine
Singer cg-590 floating bobbin keeps jumping out of it's holder.
I am trying to sew elastic right now which I do everyday. (so i'm using a zig zag stitch) Only for the last couple of days my machine is really acting up, and I don't know how to fix it. The floating bobbin holder keeps jumping out of it's place, which immediately makes a crunching sound and stops sewing. I have looked in my manual and it only tells how to remove and replace the bobbin holder, which I have done a zillion times and it is not fixing the problem. PLEASE HELP!!!
  • dirtydevildi Feb 21, 2009
    it has a little swing arm that holds it in place. But it's at the top, the bottom corner keeps jumping out.
    i'll try that thanks. I might just go get it looked at, since I need it in proper working order.
    Problem Solver:
  • 9 Answers
I'm not completely familiar with the model, but even a floating bobbin holder as you described should have some sort of a hold down. There may see a small swinging arm on the bottom right side of the bobbin area that needs to be located over the bobbin case to hold it in place. Let me know if this doesn't work.
Posted on Feb 21, 2009
  • sewrepair Feb 21, 2009
    Is there any grooves worn into the bobbin case from use. At times the thread will actually cut a groove in the plastic. It'll even cut through metal, though this usually only happens on commercial units. Try turning the machine over by hand and see where it actually grabs the bobbing case. This may point you in the right direction as to how to fix. You may be able to sand out the problem, but you may also need a new bobbin case.
I have a singer CG 590C. It didn't come with manual. I'm just learning to sew. My bobbin was hung up with thread when I pulled on it I pull the whole bobbin casing out. How do I get it back in? Help
First thing, you should probably get a manual for your machine.
Singer CG 590 Commercial Grade Manual
How to thread Singer CG 590
This machine is listed as a commercial grade professional sewing machine, so you are going to have some additional learning curve if you are just beginning to sew.
Nov 23, 2015 | Singer Sewing Machines
Model CG-550. Needle hits a bottom plate. All thread and bobbin removed. Took the feed cover off. Do not see the problem.
Possible bent or wrong needle. If ok, check the zig-zag mechanism to see if it has come uncoupled from the needle mechanism. Good luck!
Oct 02, 2010 | Singer CG550 Mechanical Sewing Machine
My machine is not shirring. I hand wind the elastic on the bobbin properly(in fact 4 different ways from no tension to medium tension on the elastic). I have it on a straight stitch and selected 4 as the...
you are doing it wrong, thread the machine top and bottom as normal, shirring elastic on your lap, select a small zig zag or pattern, sew and as you sew pull the shirring elastic taught, mif you wind the shirring elastic on the bobbin you will mess the tensions up.
Apr 22, 2010 | Brother CS-100-T Computerized Sewing...
Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Aug 03, 2009 | Janome Memory Craft 9000 Computerized...
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Brother CS-8072 Computerized Sewing Machine Logo
480 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
