Any clues? We've made sure the compressor area is free of dust and have also made sure the auger is working and there is no ice in the dispenser.
Didn't see you mention the last time you changed the water filter. For me this was the simple fix. You can find one at your local hardware store. Simply follow the instructions included. Good luck!
I had the same fridge i had to replace line in the back i dont know how but busted and when i try to get water in front door will end up in floor, also it has a selenoid that could not be working.
thanks, and good lock
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
SOURCE: Frozen water reservoir in GE Eterna refrig model GESL25XGRBS
According to factory experts, the water line is freezing in the door. There is no easy or cheap solution...they can replace the door for $300 is what I was told. The line is routed in such a way that it is not insulated enough from the cold of the freezer. Take off the bottom fan grill in front, take water line apart and cycle the water. It will pump out but not go through door. Buy a new door or go to the faucet.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
