Question about Philips Magnavox 15MF400T 15 in. LCD Television
This TV has a sleep mode
I looked it up in manual and called the company but there is not details on how to change the setting I would like to stop the TV from just turning off
  • 8,596 Answers
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Posted on Feb 21, 2009
Our Sony TV at work will not give us the option to turn off sleep mode permanently.
Go into settings, there is a option to turn the sleep mode on or off.
Oct 12, 2016 | Sony Televison & Video
WARRANTY 26" LCD HDTV W/BUILT-IN DVD PLAYER. Only 2 months old. Will not change channels by remote or manually. Shouldn't this be under some type of warranty? If not, who do I contact about parts?
only 2 months old yes you should have warrenty in the box did u get a little warrenty card at all?
if not you may call the company whp made the tv and ask them about the warrenty or ask them to fix or quote a price if it is to expensive to fix that way
you can call in the yellow pages a compony or private repairers also very cheap
Jul 04, 2008 | Televison & Video
I cant get the sleep mode off
Step 1: Wear your Fitbit Flex once you are ready to go to bed. Once you're ready to sleep, tap your Fitbit Flex rapidly for one or two seconds. The Flex should vibrate and show two dimming lights to indicate that you are in sleep mode.
Step 2: Remember that while the Flex is in sleep mode, it will not display your goal progress if you double tap it. Instead, the lights will alternate to indicate that it is in sleep mode.
Step 3: When you wake up, tap the Fitbit Flex again for one to two seconds to exit sleep mode. When you access your dashboard, you should be able to see your sleep pattern.
When you are viewing your dashboard, you can adjust your sleep mode setting between "normal" and "sensitive" modes. The normal mode shows you your basic sleep pattern, while the sensitive mode shows more details. Make sure you sync your tracker after you make these changes so that the Fitbit Flex can start recording in its new mode that same night.
Follow step 3 to disable sleep mode.
Jun 09, 2015 | Fitbit Flex Wireless Activity & Sleep...
I have a proscan tv.It has been giving me problems.When I want to change the channel.Instead of it doing so,it turns the volume up or down.When I want to turn the volume up or down, it change the chan
Are you using a universal remote control with this TV? Might be. If so, try to set it with an other code said to Sanyo Tv; with your remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 05, 2014 | Proscan Televison & Video
Tv sleep mode
Download the user manual to your set by internet. It has all details. Try this link to download it. www.retrevo.com
Oct 18, 2013 | Emerson Televison & Video
Sony trinitron tv is in sleep mode how do i turn sleep mode off
Check this link and download the user manual to your TV. Refer it. It have all details.
Feb 06, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
How to get out of sleep mode?
You turned the laptop on and off and it still is asleep?
When you turned it off did the power go completely off? If not remove the power cord to make it go off.
Try booting up into safe mode and see if it goes to sleep.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity so you can view the manual later) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Check your Power Options in the Control Panel to set your Sleep Mode and Hibernation up higher or set it to NEVER. Click Start/Control Panel and look for Power Option (it might be under System and Performance).
Below is a link to your user manual. You want to go to Pages 77 and 78 where it talks about changing the Power Plan. You want to select Change Advanced Settings as it talks about on pages 78 and you will be allowed to change the hibernate and sleep settings.
http://support.gateway.com/s/Manuals/Desktops/8512158.pdf
Jun 03, 2012 | Gateway GT5692 Desktop Computer
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
My Sony Grand Wega KF42E200A has stopped presenting subtitles at the bottom of the screen. I have them on CC1 and they just stopped working out of the blue. No changes have been made in video settings. Is...
call the cable company most cable boxes have the closed captioning feature in them and if they reset the box it will turn it off. try turning the cable box off with the tv still on then press the menu button on cable box remote( with box still off) a menu should pop up on tv screen and look at the closed caption selection if off turn on.
Feb 06, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Philips Magnavox 15MF400T 15 in. LCD Television Logo
589 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
