Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Freezer side blowing all the time and fridge side is warm with no cooling on amana side by side unpluged and defosted with hair dryer and it worked for a couple days then went back warm in fridge side fridge is only 5 years old and never had a problem till now this is a amna side by side asd2622hrq 26 cu ft
  • Amana Master
  • 3,361 Answers
You have a defrost issue.
Adaptive defrost control.
Defrost thermostat.
Defrost heater.
These are the only 3 parts involved.
If there was a model number I could be more help.
Posted on Feb 22, 2009
Side by side fridge freezer
That sounds like one of your cooling tubes is frosted up IF your fan is working. Pull the read freezer shield off and check for an ice buildup around the evaporator coil. If so, defrost circuit problems. If not, use a hair dryer and blow air down the cooling tubes to defrost the tubes.
Jan 23, 2012 | Refrigerators
My whirlpool fridge is not working, the freezer is working, I can't understand it. The thermostat inside the fridge seems to be okay, inside the fridge is not even cold. Can you help me. My fridge...
Your cooling comes from the freezer side through cooling tubes to the refrigerator side.
The first thing is to make sure that the evaporator fan is working, because that will blow the cold air into the refrigerator side. If it is working then you probably have an ice build up around the evaporator. You will need to remove the inner rear panel of the freezer to check it.
If there is a lot of ice on the evaporator fins then your defrost circuit is not working. But if you manually defrost the freezer (a hair dryer will speed it up) and make sure the cooling tubes are clean of ice (can feel the air from the hair dryer on refrigerator side) then you will have anywhere from a few days to a few weeks before the ice build up returns.
So you should troubleshoot your defrost circuit and get the parts on order to be ready for the next time.
Jul 15, 2011 | Whirlpool Refrigerators
The freezer compartment is working fine, holding at -18 degrees but the fridge section will not chill and has been holding at about 14-15 degrees for over a week but does not get any cooler than...
It sounds like one or more of your cooling tubes is blocked. Either you have a ice or frost buildup on your freezer side or something else is blocking it.
I would suggest you take a look behind the panel in your freezer and use a hair dryer or heat gun to blow warm air down the cooling tubes.
Jun 26, 2011 | Refrigerators
Not blowing cold air
Most likely evaporator coils are iced near solid...few hours unplugged would have helped just a little...needs major defrosting though.
The automatic defrost cycle will never fix it when it gets this bad...if it's still working yet.
I have one of these and have had to use heat gun/ hair dryer more than once to defrost it.
Probably the cause...which will need fixed or it will do it again sooner or latter...is the melted frost/ice goes down a little drain tube and dumps into tray to evaporate above coils...this tube gets plugged first with dust and then when melted frost drains and stands in tube the tube get plugged with frozen water.
You see it is important to unplug or fridge will self destruct.
Mar 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
176 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
