Cars & Trucks Logo
Angela B Posted on Nov 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2009 GMC Sierra front windows will not roll down. The drivers side switch when pressed will cause a click in the passenger window, but will not roll down. The rear windows and mirrors work fine from the drivers switch, just the front two windows won't go down. I've checked the fuses and all are good. Any suggestions?
William Bailey
Level 2:
Sergeant:
  • Expert 171 Answers
  • Posted on Nov 24, 2017
William Bailey
Expert
Level 2:
Sergeant:
Answers
171
Questions
0
Helped
48689
Points
502
Most likely you have to replace the switch assembly on the driver side it probably got wet over the years from rain and snow and cause it to short out. Do not get a used part from a scrap yard because your end up with the same problems.
5 Related Answers
Anonymous
  • Posted on Dec 07, 2008
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Anonymous
  • Posted on Dec 21, 2008
SOURCE: HAVE A 03 GMC SIERRA
I had the same problem in my wife's 2003 Yukon Denali. The power seats and passengers side window wouldn't work. Turned out to be a blown Buss Type fuse in the Underhood Fuse Block. It is the one marked MBEC 1 50amp. Hard to tell if the are blown so look very carefully. Should look like a hoop with two shiny solderlooking bubbles on either side. On my blown fuse, it caught my attention because it looked like the solder was missing and I had to look very closely to see the bottom of the "hoop" was open. They are very hard to remove and must be pulled straight up.
This type of fuse looks like a red square with a clear plastic top showing the fuse link under the plastic. On my vehicle it is on the top row second one from the left.
Anonymous
  • 77 Answers
  • Posted on May 13, 2009
SOURCE: Divers window won't roll up my Camry
No won't be fuse. My guess is there is something faulty with the main controller. You could probably verify this by trying the switch on right rear passenger door. If it works there then the problem is at the main controller in the driver door. Could be a loose wire or the switch itself is broken.
Anonymous
  • 145 Answers
  • Posted on Jun 08, 2009
SOURCE: 1999 Dodge Durango driver side window does not roll up nor down.
Remove the door panel and find the window motor Unplug it and using a separate car battery run cables directly to the window motor When you switch the polarity the motor will either bring the window up or down or if noting happened change the window motor and window regulator assembly.
Anonymous
  • 127 Answers
  • Posted on Nov 18, 2009
SOURCE: pass. side front and rear power windows stopped working
if they only stoped working on the passengers side I would check the wirring going into passengers side door for a broken wire, or right at the passengers side kick panel.
99 durango, both front and back passenger side windows dont role down. driver side front and rear role up and down fine
There are a few possible reasons why the front and back passenger side windows on your 99 Durango aren't rolling down:
  1. Faulty window regulator: The window regulator is the mechanism that moves the window up and down. Over time, the regulator can become worn or damaged, making it difficult or impossible to operate the window.
  2. Electrical issue: It's possible that there's an issue with the electrical system that powers the passenger side windows. This could be caused by a blown fuse, a faulty switch, or a problem with the wiring.
  3. Window motor failure: The window motor is responsible for moving the window up and down. If the motor is faulty, the window won't move.
  4. Window switch problem: The window switch could also be the culprit. If the switch is damaged or not functioning properly, the window won't roll down.
To diagnose the issue, you can start by checking the fuses related to the power windows. If the fuses are intact, you can use a voltmeter to check if the switch is receiving power when it's pressed. If the switch is getting power, the problem could be with the window motor or regulator.
If you're not comfortable performing these diagnostic steps, it's best to take your Durango to a qualified mechanic or automotive electrician for further inspection and repair.
1helpful
2answers
2009 GMC Sierra , both passenger window wont go down , driver side do. What’s wrong with the passenger windows.
Hi friend, firstly on the main command where you can control all the windows has a button that when you put it off only the driver's window will work, so you have verify if the button is not activated!! .if it's not activated then you will have to control the fuse related to the windows, an if all the fuses are fine then go to the windows motor .
I have an EOS VW 2009 and it had 5 window switches in the driver side door to the front windows and back windows and a switch to push all four windows down/up at the same time. But right now my passenger...
Hi Kimberli,
I suspect that since all windows can be powered up and down, you have issues with I believe 2 specific switches you mentioned that have problems - as a result of possible rain water, melting snow / ice or spillage of beverages. You might be able to clean them up - or replace the ones that are "flaky"
1helpful
3answers
2.7l dodge charger passenger window rolls down but not up
my car doing same thing I replaced the regulator and still does same thing HELP
My power window on the drivers side of my 2002 gmc sierra 2500 will not roll up. The problem is not the fuse. When you press the switch you can hear the motor trying to kick on, its not a whine, just a...
it is 8 years old and it is the most used window. it needs a new regulator, buy one at a parts store or on ebay and pay a glass shop to put it in for you.
3helpful
2answers
Power window switchs on 1996 gmc jimmy
Inspect or replace the window lock and unlock switch on the drivers door power window switch. There is a lock and unlock switch that will disable the switches to the other power window in the Jimmy. Check to make sure that switch is in the unlock position to have the other power window switch to work.
Thank you for suing fixya and good luck.
2helpful
Passenger window rolls down window but does not roll up
replace the switch. They have parts made of plastic pressing on the contacts softing these babies up making them useless in a few years
1helpful
Passenger side window won't roll up using the driver's side switc
Before you replace anything, inspect the connector pins in both the driver's door switch and the passenger door switch. If you don't find any problem with these connector pins, replace the driver's door control switch.
The windows don't work right
If the passenger front window switch operates up & down correctly the left drivers side switch is bad and needs a replacement switch
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
