Televison & Video Logo
Posted on Mar 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code for pdi tv - Televison & Video
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 04, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003297
Points
237762
0361,0284,0283,0279,0241. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and proceedings to some popular model remote control are given.
Remote codes for pdi tv
I have no listing for this bran name TV
Pairing codes for 2010 PDI TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
My evershsm tv does not come on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
[This TV uses PDi TV kit.].
How do I get a remote for a PDI TV
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
2answers
2005 honda odessey radioi code
You need the serial # and reference # off the sticker on the radio. Call or visit Honda with VIN and ser #'s and they will provide the unlock code for you. It's the only way to get it, if you lost the original audio card that came with the vehicle new. Look in the glove box, or door jambs for the extra ID sticker that should have been installed at PDI when the vehicle was new. Occasionally techs put the wrong one there that actually has the unlock code on it. If not, it's easy number gathering without needing to remove the radio.
2helpful
I have a 2007 Honda that the navigation system is asking for a code. What is the code and/or how do I get it,.
Check inside the wall your glove box first. Sometime the Honda dealer that PDI your car will place a white sticker with your code or SN# of the navi on it.
If not, the navi unit is located in the ceiling of truck area between the speakers. It looks like a c/d player.
Pull it out and you can get the SN# on it. Just call you Honda dealer and give them the SN# and they should be able to give you the code. good luck
2answers
Vbag activation code
hope this is not too late here is your activation code 010196980760384123456789012345
you find this solution helpful, pls don't forget to rate and vote
thanks for using fixya
2answers
Hi, I replaced my honda pilot/03 battery and now my radio is locked...
First open you glove box and look on the sides of the glove box. Look on all sides. Then check your owners manuel in secruity codes section. If the tech who did the PDI On the car did it properly you should have the code written in then and a sticker on the outside of your glove box.
If not then call the dealer and they should be able to look it using you VIN number,
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
