Question about Milwaukee Tool Factory-Reconditioned Milwaukee 6140-8 4-1/2-Inch Sander/Grinder, 5.5 Amp, 10,000 RPM, 5/8-Inch x 11-Inch Spindle
Need brushes and on-off switches for milwaukee 6140-6 hand grinders is this grinder obsolete?
  • 2,176 Answers
I would need the exact model number and serial number to help but the brush number is 22-18-0710 and there could be a couple different switches. Either give the ser number (the alpha code) or you can go direct to Milwaukeeelectrictool.com and type in the model number 6140 on the page for the breakdown. it might be easier to let me do it. I worked there for 17 years and if you can't get the alpha code look at the switch and I would need a good description of it
Posted on Feb 21, 2009
How to replace milwaukee C18ID brushes
That model may be one of those that really isn't meant to be replaced, you can try to do it. I've been the shop maintenance mechanic and have come across some Milwaukee tools grinders that were made to be throw aways! They made them so you could replace the on/off switches but brushes were the real problems with them. They were so short and tiny that they would wear out within a month of constant use. If the brushes didn't go the bearings would melt and the entire case would need to be replaced. The brush assemblies may be available if you order them from Milwaukee directly.
They are not like they old style that would be a piece of brush with a copper braided lead protruding out. Those would just drop into the slots and the spring holds pressure on them. You can find some brushes and shape them yourself as I have done with these newer tools. You'll find the springs are now part of the holder assembly and is a curled piece of spring steel that holds the pressure. So be careful if you try to reuse the assembly with another generic brush set. They will have a special shape also to deter you from using a longer lasting brush by having an offset in the design or a groove which can be flattened. I found the shapes to be like 2 squares that are offset but a rectangular shaped brush will work after its reshaped by a sander or grinder. The Milwaukee brush was 1/4" long new, replaced with 5/8" once the holder was modified, then the bearings just melted, cases melted and the motors rubbed on the windings. But I never had to replace the brushes again. Average life was between 2 weeks to 4 months (new), Hitachi similar grinders lasted 5 or more years with 1 or 2 brush replacements.
Either way you're going to take the tool apart yourself to replace them, just depends on the availability of replacements assemblies. Also the cost, you may as well order 4 sets right away if you are going to use Milwaukee's new garbage sets. 20 years ago I used a similar grinder for 5 years of constant every day use, replaced the cord a few times, never had any other problems.
Now I wouldn't even bother to take them apart, just about every other brand made is equal to or better than Milwaukee and cost 1/2 as much plus they use interchangeable parts. Now you're paying for Milwaukee's redesigning and engineering teams quest to constantly change parts, making sure that you cannot service them using any old parts. Right down to the cords, they spend all their money on developing new ways to do the same thing but making sure it is not compatible with last years models parts. Once your tool is made outside the USA there's no reason to buy any 1 brand, they will all be the same in the end and just dyed a different color and have labels stuck on the cases.
Sep 23, 2014 | Drills
Need switch for milwaukee model no 6066 serial no 0075355593 sander/grinder.please help THANK YOU.
Part # 50
http://www.ereplacementparts.com/milwaukee-6066-ser-753a-sander-parts-c-131_4779_5141.html
Aug 12, 2013 | Milwaukee Tool Milwaukee 6066 - 6 7''/9''...
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
I need instuction manual for a Milwaukee sander/grinder
go to milwaukeetool.com and you can download the owners manual, you will need the serial number to ensure that you get the right one. Let me know if you need more assistance
Sep 23, 2011 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
How do I replace the metal grinder?
Replacing the blade is simple. look for the lock button on top of the unit and use a tool or spanner wrench to loosen the blade.
Good luck
Joe
Feb 14, 2011 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
Milwakee grinder 6140, heats up runs slow and makes noise
check the commutator bearing and also to see if armature rubbing field. Let me know if you need more help. You can get a breakdown at Milwaukeetool.com
Mar 15, 2010 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
No power nothing happens
Milwaukee tools have a 5yr warranty, best thing to do is to take it to a service center. It could be anything from the cord to switch, brushes, field coil etc. If it is newer than 5 yrs, thats the best route.
Feb 06, 2010 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
I cannot get off the abrasive cutoff wheel I put on the grinder
I believe the thread is left hand, but close inspection should verify. Also you should never over tighten cutoff wheels or grinding wheels. You should be able to remove with a gloved hand while holding button on top with the other hand
Dec 26, 2009 | Milwaukee Tool Milwaukee 6" Right Angle...
Cannot figure how to get the point onto the die grinder.
Here is a link with illustrations on installing grinder points. Scroll about 1/4 of the way down and you'll see two links for "Operators Manual" Click the one that matches your model.
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/All.aspx?ProductId=5192
Hope this helps you out.
May 31, 2009 | Milwaukee Tool Milwaukee 5192 4.5 Amp Die...
Milwaukee Tool Factory-Reconditioned Milwaukee 6140-8 4-1/2-Inch Sander/Grinder, 5.5 Amp, 10,000 RPM, 5/8-Inch x 11-Inch Spindle Logo
140 people viewed this question
Top Milwaukee Tool Tools & Hardware - Others Experts
Bill Boyd
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Milwaukee Tool Tool and Hardware - Other Expert? Answer questions, earn points and help others
