Local channel went digital, lost signal.
Local channel went total digital. Lost signal. I rescanned and still no channel. I have a VHF/UHF atenna plugged in to the TV. Coby 19" LCD TV
  • 1 more comment
  • fitchca Feb 20, 2009
    The tv is digital not analog. I receive all the other digital channels. the UHF & VHF is the atenna
    Sorry for the rating. Yes my tv is digital as I get all of the other digital channels. I sent this same type question to the tv station and they suggested "Sometimes re-running the TV's "initial setup" procedure will rescan all available channels and pick up the new ones added since the first time the tv was setup. That should be mentioned in the user manual for your set." I don't remember a initial setup for the TV. Any suggestions??
    Again sorry for the rating did not mean to lower your rating.
  • Ralph Marriott Jul 10, 2013
    I have tried that but still the signal goes. The fault occurs after different periods of time and temporary cured by switching off. Looks like electrolytic capacitor failure to me
  • 15,935 Answers
You need a digital to analog convertor box to recieve the digital signal.
All UHF+VHF signals will be digital starting in June.
Thanks for using FixYa - a FixYa rating is appreciated.
Posted on Feb 20, 2009
  • blueextc3221
    blueextc3221 Feb 20, 2009
    If it only happened to only that particular channel - chances are it is the station's problem... and not with your TV.
    Check it again in a few days - or try an auxiliary station. ie. if it was channel 20.1 try 20.2 or 20.3.
    Also, please reconsider your "Thanks for Trying" rating. Very few experts on FixYa answer "Freebie" questions, and those of us that do spend the time to respond are taking the chance of our ratings going down attempting to answer questions like yours with little to no information.
    Here is what i see in your question....
    Local channel went digital (assuming the Feb 17 deadline).
    You lost signal (again - assuming lost in the digital conversion on the 17th).
    You re-scanned (your TV) and still had no station.
    You have a VHS/UHF antenna installed (no mention of a Digital TV convertor)
    Coby 19" LCD TV (again no mention of HDTV or HD Ready - LCD is not indicative of being HDTV Ready.... my 42" plasma is not HD ready)
    I answered the question to the best of my ability with the information you provided. A thanks for trying rating (misworded by fixya in my opinion) has the same effect as an Inappropriate - it lowers my rating by almos a full percentage.
    A "Helpful" rating would be appreciated!!
  • blueextc3221
    if you reply with your TV Model #, i can search for your user manual & help you further.
    Thanks for the rating change!!
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
I purchased a nexxtech VHF/UHF/FM Indoor Antenna to bring in digital signals to my HDTV. It helps with the one analog channel that I receive (CBC), but does not bring in the other channels that should be...
But the antenna u bought it is a digital antenna design though.Digital antenna design will help ur tv to getting broadcasting signals channels stronger and longer signals ranges though.
Sep 06, 2011 | Televison & Video
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
Since the digital switchover, I have lost channels, despite re running the setup and tuning. Any suggestions as to why this is happening?
I have a similar issue. When the digital switch happened here some of the local TV stations changed frequencies from UHF to VHF. I do not have a VHF antenna so I am unable to receive these channels. I do have a great UHF antenna, but it will not receive VHF. The fix is of course is a new UHF/VHF antenna. I am 50 miles away from the TV transmitters.
This may or may not be your problem. I hope this is helpful to you.
Bob
Nov 08, 2009 | JVC LT42P789 42 in. LCD TV
Lost signal
Tv tuners for laptops and desktop computers require amplifier for cable signal please check you are using uhf or only vhf channels then choose the amplifier as they are very cheap like antennae boosters.. The channels with the weaker signal will become avaliable
Aug 06, 2009 | IBM ThinkPad T20 2647 Notebook
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
I have had 2 converter boxes from the begining and now both have decided not to work. I tried to rescan, bought new batteries, repostioned the anntenna and nothing works. When I tried to rescan, nothing...
You need to check your antenna strength, this is done through the digital converter box. Those channels may have lowered their broadcast signal and your antenna cannot pick them up anymore. You may need a outdoor antenna to pick up the channels. These can be purchased at any home improvement store. There is no such thing as a digital antenna. They are broadcasting digital signal instead of analog over UHF stations instead of VHF in most markets.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Conversion boxes-Do I need one with an outside atenna?
you will need a converter box if you do not have a digital ready television. If you have a digital television, then no you do not need one. make sure of the type antenna you have, as there are uhf only and vhf only and combined uhf/vhf. if you only have a uhf only antenna you may be missing out on channels.
Jan 23, 2009 | Televison & Video
Televison & Video Logo
465 people viewed this question
Top Televison & Video Experts
Electro Med Services...
