Question about Dell Inspiron 9100 Notebook
Trusty Inspiron 9100 died suddenly, now won't power up...
I have an Inspiron 9100 that has served faithfully for about five years. Although now demoted to backup use, I was using it the other day when, suddenly, with no warning or prior indication of any kind, completely shut down. Although it restarted and ran again for a period of time, it shut down again and will no longer restart.
The only symptom I can describe is that when I press the power button, the power LED comes on, and the bezel status lights illuminate normally, but the fans/hdd never spin up, and no display of the system even attempting POST occurs. After a few seconds, the lights extinguish.
The battery indicates a full charge, and the charge LED on the back of the case indicates it is taking charge as if all is normal, so that leads me to believe at least the basics of the power subsystem are intact. My first guess is that one or both fans have failed, and such a failure will prevent the system from even attempting a start to prevent heat failure.
I have removed and reseated both RAM sets, removed both fans (both of which seem to spin freely, and there is no aura of burn odor that one might associate with a worn bearing), blown out any apparent dust, all to no avail.
As noted, this is a secondary system, but I would sure like to squeeze a bit more life out of it if possible. Any suggestions appreciated.
-David
  • 1 more comment
  • soonerdew Feb 20, 2009
    This system is long out of warranty, and I am entirely willing to explore and attempt repair myself. This has been an excellent system and would be worth the expenditure of a few dollars on some 2nd-hand/refurb parts before I declare it deceased. I've torn down other laptops before and had some success in the past, so I'm willing to try on this beast.
    -David
  • swiftgc1b Mar 15, 2009
    I have 9100 xps and when power button is pushed nothing happens except light next to power button lights up for about three seconds and goes out.   Help please.
  • Anonymous May 10, 2009
    I have the exact same issue. I really want to get this system up and running again. Today after getting the HD out and putting it back in it started up again but after a couple of minutes just as I saw all my icons appear the screen went black and nothing responded. Hope anyone can help.
  • Dell Master
  • 13,433 Answers
Hey,
This could have been a overheating issue thats damaged the components already.
I'm sorry but over the internet I can see what the problem would be, Would need to inspect and test it closely.
I would suggest you get it looked at by a professional, if you only get a recommendation to replace the motherboard and a 200-500 repair estimate I suggest trying another professional.
there are people out there who repair motherboard. I've seen some deals on ebay for repairing a motherboard and it might be cheaper to get the motherboard repaired if its indeed faulty instead of getting it replaced.
Replacement is obviously the easyer process and thats what most professionals offer.
If you are fimiliar with electronics, you could test the fans yourself by taking them out from the computer and giving the required input voltage on the red and black wires. and see if it spins properly.
If it does spin fine but not on the computer, that would suggest a hardware issue on the computer possibly motherboard or other component failure.
But again this is just guessing over the internet without inspecting the laptop.
I'd suggest to find a professional who is willing to look into it in detail without a huge bill.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 20, 2009
  • Ekse Feb 20, 2009
    I suppose the warranty is out?
IT IDLES DOWN TO WERE I HAVE TO MASH THE GAS AND BRAKES WHEN I COME TO A STOP SIGN..AND ITS RUNNING HOT
I had somewhat the same problem early this year. My trusty mechanic surprised me by saying that the injector lines were dirty. It surprised me because I had been pretty faithful in putting injector cleaner in the gas tank on each oil change.
May 09, 2014 | 1992 Lexus Es 300
I have reinstalled the software on my Inspiron 9100. Everything installs fine until I install either the Intel chipset drivers or XP SP2 or SP3 updates and then after a reboot the screen displays...
Sounds like a problem with the Video Driver...You can always opt out of installing the chipset driver as really the computer can run without it. Does the Dell website have alternative chipset drivers for this model besides the Intel one? If so try it.
Jun 15, 2010 | Dell Inspiron 9100 Notebook
Viking 6000 (model 6440)sewing machine - replacement motor
a quick check on your motor. If it gave a lot of smoke and really thick and heavy oily smell all of a sudden, then your capasitor blew. your machine can work without it. Test your machine to see if it still work as normal. Your motor is still good then and only needs replacing fo the capasitor. This is a common problem!!
Jan 24, 2010 | Husqvarna Sewing Machines
My dell inspiron 9100 wont start the operating system and the little light with the A in the middle blinks and then turns off can u help me?
Remove the battery the ac adapter,the memory.the hard drive and the cd rom.Press and hold the power button down for twenty seconds.Replace the memory first then the battery and the ac ,power up if this works add the other pieces one by one.REMEMBER BEFORE YOU ADD EACH PIECE THERE MUST BE NO POWER ,NO BATTERY OR AC ADAPTER.
Good luck
Nov 14, 2009 | Dell Inspiron 9100 Notebook
Inspiron9100 charges the battery, but does not run off it
you've got a dead cell in the battery pack. Replace the cell (there're howto's dotted around the web) or replace the battery pack.
Jul 21, 2009 | Dell Inspiron 9100 Notebook
Run MS Vista on Dell 9100
The reason they told your daughter that is because either there isn't a powerful enough CPU and enough memory to support it and also there are no vista drivers for that laptop on Dell's website.
If you decide to put vista on that laptop your going to need to make sure that whatever hardware drivers vista doesn't detect, you'll need to search on the net to find vista compatible drivers if they are out there, it will be time consuming.
My recommendation from my own experience, make sure you have at least a 2GHz processor and 1GB or memory.
May 18, 2009 | Dell Inspiron 9100 Notebook
Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system: http://www.dellweb.co.uk/spares/inspiron/9100.htm
Feb 04, 2009 | Dell Inspiron 9100 Notebook
Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
Dec 10, 2008 | Dell Inspiron 9100 Notebook
Maytag DE 412
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
May 25, 2008 | Maytag PYE2300AY Electric Dryer
Dell Inspiron 9100 Notebook Logo
540 people viewed this question
Alun Cox
