Question about GE JVM1631 Microwave Oven
I have a GE Jes1288 microwave which my wife open the door on and the light blowed out and now it will not come on at all. I have unpluged and ck .. We do have power to the outlet.
  • 52 Answers
When you say it will not come back on, do yo mean the lamp or the machine.
If you mean the machine, it is possible the door switch protection circuit has caused the problem. remove screws and take of cover look for a fuse inside the machine it can be anywhere.
I know companies that charge £100 for this minor repair
Posted on Feb 21, 2009
Counter top ge microwave did not heat. Ck all the sw and everything else & all seems fine. Put back together but now open the door and fan and light comes on, still no heat
Most likely the magnetron has went bad though there is also a high voltage rectifier diode which could be bad. These can be replaced but be aware that they are in the high voltage section of the microwave.
The website below has a video (not mine) showing what is involved in changing the magnetron. You need to follow all of the safety recommendations shown (most important is to short the high voltage capacitor as it can store voltage even when the appliance in unplugged).
youtube magnetron replacement Yahoo Video Search Results
Dec 09, 2017 | GE Microwave Ovens
Fan blows when doors open
One of the three door switches has failed and will need to be replaced. You would need to access behind the control panel to check them and or replace it. Good luck
Feb 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
Fuse blow when door opens
I would replace the light bulb. If the fuse still blows, then it is going to have to be the door switch.
Jan 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE microwave for three months bought it brand new and wife was making potatoes in it opened door to check on them and then closed door to continue cooking and it continues to count down but light...
The door switches are slightly out of alignment. If you run the microwave and shift the door up or down, the micro might begin working..
The control panel must be removed and the door switches adjusted. I would not suggest you doing this yourself, as it may affect the microwave leakage through the door gap.
Jan 02, 2011 | GE Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Jan 21, 2009 | GE JVM1631 Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Ge sca1000h
UNPLUG THE MICROWAVE FROM THE ELECTRICITY,,,,AGAIN,,,UNPLUG THE MICROWAVE FROM ELECTRICITY---NOW ,SOMETIMES YOU CAN SEE A TRAP DOOR LOCATED ON THE OUTSIDE OF THE CABINET --THE SIDE WHERE THE LIGHT IS ,, MAY NEED A PHILLIPS HEAD SCREWDRIVER,,THE LAMP IS THERE--DID I SAY ---UNPLUG THE MICROWAVE,,YES ..IF YOU ARE NOT COMFORTABLE WITH THIS --DON' T TOUCH IT !!!!!! TUNICA
Oct 30, 2008 | GE Advantium SCA1000H Convection /...
Where do I find the fuse?
yes you do and this is not reall advisable as there is high voltage components inside.thre is normally a fault with the machine if it blows a fuse.if you want to still try then make sure yoiu unplug it and short the plug on some metal to get rid of any stored charge.the main things to blow a fuse is the door switches sticking,the bulb blowing or a fault with the high voltage system which you would need a special multimeter to yest,hope this helps
Jul 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1631 Microwave Oven Logo
122 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
