Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Tatung L15CCAE Monitor 15" Shuts off after 10 minutes.
Problems:
*Blue light stays on even when screen is blank.
*No capacitors visably damaged
*on/off switch will not return the screen to working order, the power cord must be removed.
*nothing getting especially hot on the boards
History:
*Left on straight for about a year and a half. used as a fast food order screen.
3 Suggested Answers
SOURCE: Monitor problem
You need a new monitor
Posted on Mar 12, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Hanns-G Model HG281DJBUF101 monitor.
Please read my guide and look real close at the caps and voltages.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 14, 2010
Toshiba sl738b
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Toshiba Televison & Video
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Samsung 540N monitor. Takes more time to start the display
this is capacitors problems inside the monitor. If you have some tools , screwdrivers, soldering iron and some experience, open carefull the back of your monitor after to unplug from the outlet.
you will see in power supply board a capacitor who which the top has changed . replace that capacitor.
Sep 12, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen is blank.
Could have blown some capacitors inside the monitor.
I just fixed one today that had no power, the blue ring around the power button didn't even light up when plugged in.
I open it and found 3 bulgingcapacitors on the power/inverter board.
They were all 25V 470uF rated capacitors.
Went to radioshack and found 2 35V 470uf, got them at $1.29 each, then I found 1 50V 470uF out of a dc car power adapter for an ipod, it was as close as I could find.
Replaced the 3 broken/bulging ones with the new/salvaged ones, put it back together, plugged it in and the blue light came on when I pushed the power button.
Plugged it in to my laptop with vga cable, and it works great.
Oct 24, 2008 | Samsung SyncMaster 932B LCD Monitor
Blank screen
bad capacitors on the power board the need to be repaced with new ones soldering wil be required
Jul 24, 2008 | Dell E153FP 15" LCD Monitor
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Jul 07, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Blank screen for 15-20 minutes at startup
I have a Xerox XA7-19i. It has the same problem as described by many others - intermittent fault with the display that manifests as a white screen when the monitor is first switched on. After a few trys of switching on and off, the monitor works fine until left off for a few hours. Recently, the problem deteriorated to no light from the panel, and a flashing blue power light.
I HAVE SUCCESSFULLY REPAIRED MY MONITOR:
I opened up my monitor and removed the power supply board.
I de-soldered every electrolytic capacitor, and replaced them with new capacitors of the same uF and voltage rating.
I put the monitor back together again and switched it on - it worked perfectly!
Yes - these monitors have been built using sub-standard / under-rated electrolytic capacitors. After two years of use, the power supply board was unable to supply enough power to the logic board and backlight, causing the above-mentioned problems.
The repair cost me ~ GBP 15 (USD $30). It is not a difficult fix, but one only to be attempted if you have electronics knowledge. Careful, kids! you'd be playing with the power supply of a mains AC electronic device. That stuff can kill.
But - I saved myself (and the environment) from having to throw out a monitor and buy a new one. If you have a faulty xerox monitor and are getting no love from Xerox customer support, find an electronics geek and ask them to replace the electrolytic capacitors on the power supply board. (but be careful to get the right kind of capacitors, and to get the capacitor polarity correct. If you have any doubt as to you ability to do this, don't bother trying!).
Sep 02, 2007 | Xerox XG-91D 19" LCD Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
109 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
