Question about Zanussi ZDC5350W Electric Dryer
Zanussi TC 485 W Dryer works fine, but isn't producing heat
My Zanussi TC 485 W works fine, but isn't producing any heat. I've emptied the Water and filters but no joy... is there something else I can try or will a part need replacing or worth buying a new Dryer ???
SOURCE: Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Posted on Mar 01, 2009
  • 1122 Answers
SOURCE: No hot air is being produced from my Zanussi TC 180 condenser dry
what make is it?is it a top lint screen or inside?
Posted on Mar 31, 2009
dushko
  • 59 Answers
SOURCE: Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Posted on Apr 15, 2009
SOURCE: zanussi tc 481w codenser dryer
this is possibly the belt slipping remove back panel and check the belt tention if not that it could be the bearing needs replacing
Posted on Sep 02, 2009
heatman101
  • 43501 Answers
SOURCE: I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 20, 2010
Zanussi dryer tc
Did you locate the "tensioner" wheel that may have jumped out of the mounting hole...??
There are two wheels, one on the motor and one on the tensioner...
Apr 13, 2014 | Zanussi TC7114W Electric Dryer
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Zanussi condenser dryer TC 7114 w. It stops half way through the cycle indicating the water tank is full, but it is vertually empty and the water is collected in back of dryer and then leaks all...
I have just fixed this as below - your leak may be easier to see if you turn the machine on its front - there is a rear valve with a rubber bung and underneath a rubber pipe with a metal clip - check both for leaks - http://www.fixya.com/support/t4079509-full_water_indicator_lit_continuously
Oct 04, 2010 | Zanussi TC7114W Electric Dryer
I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT SEEMS FINE, THERMO ALSO FINE BUT STILL NO HOT AIR BEEING CIRCULATED
heatman101
Aug 20, 2010 | Zanussi TC7114W Electric Dryer
How to use my condenser dryer zanussi zdc 47100. do i fill the bottom bit with water or leave it empty ? just bought it second hand but has no manual !!
this is a drier ? and therefor no water is needed however you will need to ventilate to outside via the conveluted white hose that fits to the machine to prevent the damp exhaled heat fro machine condensing in the room dryer is positioned
Nov 27, 2009 | Zanussi Dryers
Zanussi tc 481w codenser dryer
Aug 16, 2009 | Zanussi TC7114W Electric Dryer
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Mar 31, 2009 | Dryers
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Dryer not working
If the drum is not moving: There is something stuck inside your furness blower( could be some pice of cloth). Open the furness and remove the piece and your dryer will be working fine afterwords. If the Drum is working fine; the coil valve, fuse or the gas ignitor could be the problem; usually repacing the coil valve will fix the problem
Oct 14, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZDC5350W Electric Dryer Logo
174 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
