Question about Lucent PARTNER18 Corded Phone
Wv now need to dial the area code along with the 7 other numbers. I have lost the instructions for programing the numbers. i have a lucent technologies , # 925, 16 programable # can anybody help? GLENN
    President:
  • Lucent Master
  • 860 Answers
Heres the users guide for that model,
http://www.k-state.edu/infotech/voice/925.pdf
hope that helps
Posted on Mar 17, 2009
Zip code for south africa
South Africa - Country code = +27
ZIP
codes are a system of postal codes used by the United States Postal Service (USPS) since 1963. The term ZIP, an acronym for Zone Improvement Plan, was chosen to suggest that the mail travels more efficiently, and therefore more quickly (zipping along), when senders use the code in the postal address.
To call South Africa from the U.S., just follow these dialing instructions: First dial 011, the U.S. exit code. Next dial 27, the country code for South Africa. Then dial the 2-digit area code (see sample calling code list below) followed by the 7-digit phone number.
South Africa Telephone Code 27. South Africa telephone code 27 is used to make international calls from South Africa. You may also see 27 referred to as the South Africa country phone code, or South Africa international calling code.
Nov 18, 2016 | GPS
I need to block certain extensions from being able to dial long distance
Best way to do that is to sit down with the manual and look at programs 400-408. At a minimum, if you restrict 1 and 0 in a table and assign it to your extensons in 405, those phones can't dial long distance. That's fairly worthless in today's calling climate when some carriers let you dial just 10 digits or you have to dial 1 for any local call outside your area code. 404 lets you build 8 tables of 10 number sequences each for restriction and 407 lets you build 8 tables of 10 number sequences for allow. For example You could put 1 HOLD HOLD HOLD (hold is the wildcard) in one table and entry of 404 with traditional dialing and that would restrict all 1+ long distance. Then, in 407 5 of your entries in one table would be 1800, 1888, 1877, 1866 and 1855 to allow toll free calling. These tables get assigned to extensions in programs 405 and 408. A simple restriction (ie local calls only, internal calls only) get assigned in 401. There are some other tricks and, above all, remember that you have to keep 911 availabe for access and allowing 0 is never a good idea because 0 alone will get the operator and that defeats the purpose of toll restriction.
Other tricks involve custom CLASS codes. You need to account for the clever worker who dial *67. That gives them second dial tone and they can dial the world. It would be easy if you could block first digit *, but you ought to allow *57 for nuisance call trace. If you have the above where long distance is dialed with only 10 digits, then you can always start with HOLD HOLD HOLD in a table and allow 911 and the local area code in an allow table. The table digits can be up to 12 so you may have to go to 6 digit screening in allow tables for local exchanges. In my area, we have 10 digit dialing and 419352 419353 419354 (among others) along with 567213 are local calls. If I were programming a customer 6 miles to the North, there would be extensive programming in both area codes.
Outside of that, it's just a function of analyzing your local calls, area codes, how a call is dialed, and building your tables. We do this with billing by the hour :-)
Carl
Apr 07, 2011 | Lucent PARTNER18 Corded Phone
Lucent Partner phone speed dial
At ext 10 or 11, press feature 00
then feature and 600 or whatever code you want
then enter the number as you would dial it.
when done, enter feature 00 to get out of programming.
May 10, 2010 | Avaya Lucent Partner 616 Phone
How do I change the time on my INDIVIDUAL Lucent Partner 18 phone? The time on my individual phone display is different that that for the system as a whole and the opther phones. Also , How do i program...
To change the System Time:
  1. Press feature +(00)+(left intercom)+(left intercom)+#103 at extension 10 or 11.
  2. Enter a new time in 24-hour notation. For example, to set the time to 2:15 p.m., press 1415.
    A display similar to the following appears:
    System Time
    Data 1415
    This time appears on system display phones as 2:15 p.
    to program speed dials, press feature + (00)
    press the button you want to program
    dial the number you want programmed, then press feature 00
Jul 27, 2009 | Lucent PARTNER18 Corded Phone
How to program 6221 Avaya Lucent Analog 10 button Speed Dial Speakerphone - 10 storage area's on the phone - don't know how to program numbers in the phone ???
While the handset is on hook,
1. Press "Program" 2. Press the desired Speed Dial botton 3. Enter your to-be-stored phone number 4. Press "Program" to end the session.
Jul 14, 2009 | Avaya Definity 6221 Corded Phone
Need to change the main greeting on our lucent/partner system?
You need to press 0 at the voicemail login prompt. If you dont have a button programmed you can dial Intercom-7-7-7. If the system is configured properly you will get the login prompt. You can then dial 0# for the admin login. The default password is 1234#
May 27, 2009 | Lucent PARTNER18 Corded Phone
Call fowarding to cell phone
from the merlin phone pick up the phone for a dial tone then hit *33 and it will say "forward to:" then dial 9 + 1 + area code + phone number.
To undo the forwarding follow same procedure but when it says "forward to:" enter your merlin extension number.
May 15, 2009 | Lucent Merlin Legend MLX-20L Phone
Programmed numbers
Feature 00
Press button to program
enter intercom+number to dial
Feature 00
Aug 22, 2008 | Lucent PARTNER18 Corded Phone
Power outage lost fetaures
Contact these guys (sorry they dont still have a manual online); http://www.alcatel-lucent.com/wps/portal/ContactUs Hopefully they can help you out :)
Jun 27, 2007 | Lucent 1872 Corded Phone
Lucent PARTNER18 Corded Phone Logo
96 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
