Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
All my usb ports are not working when i connect any pen drives or external hard disk or bluetooth deice my computer doesn't read them what should i do?
  • 3 Answers
Check inside ur computer usb port lead is not connected to the motherboard.....if it will not connected to the so, plz check ur motherboar cnfiguration and download the images...that will show how to conect everything like wire,cmos battery,usb port etc....
Posted on Apr 15, 2009
Note boot the system into SAFE MODE and perform the following steps.
1.Rename the following usb files:
usb8023.sys
usbcamd.sys
usbcamd2.sys
usbd.sys
usbehci.sys
usbhub.sys
usbintel.sys
usbport.sys
usbuhci.sys
usbprint.sys
* Note those files are located in c:\windows\system32\drivers. Also rename the
files to a *.old
extensions or to what ever suits you best*
2. Rexpand or recopy the following files
usb8023.sys
usbcamd.sys
usbcamd2.sys
usbd.sys
usbehci.sys
usbhub.sys
usbintel.sys
usbport.sys
usbuhci.sys
usbprint.sys
*Note you can rexpand these from the xp cd rom or copy them from the
c:\windows\servicepackfiles
\i386 folder if it exists.*
3. Rename the oem*.inf to oem*.old in c:\windows\inf
4. Rename the infcache.1 to infcache.old in c:\windows\inf
5. Unplug usb devices from teh system
6. Remove all usb devices from the Uninversal Serial Bus Controllers section of
Device Manager
7. Check for and delete any filters in
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{36FC9E60-C465-11CF-8056-4
44553540000}
8. Take ownership then backup and delete the 4 digit subfolders in
44553540000}
9. Take owenership then backup and delete the following registy keys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB Printers
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB Storage
10. Reboot the system into normal mode
11. The system may or may not come up with a new hardware wizard screen for the usb
devices.
12. Check device manager for Uninversal Serial Bus Controllers. It should now be
back
13. Plug in usb devices and everything should detect now.
Posted on Mar 12, 2009
    Problem Solver:
  • 12 Answers
Plese make sure that your USB port is enabled in BIOS Mode,
if it is enabled make this steps....
Download USB Driver files....
usbehci.sys
usbport.sys
usbhub.sys
usbui.dll
usbccgp.sys
usbohci.sys
Posted on Feb 24, 2009
  • mml251089 Feb 24, 2009
    also u can find out this files in your xp c drive folder.....
    C:\WINDOWS\Driver Cache\i386\sp3.cab file...
    copy all usb* files in c:\windows\system32 and c:\windows\system
    usbehci.sys
    usbport.sys
    usbhub.sys
    usbui.dll
    usbccgp.sys
    usbohci.sys
120G hard disk doesn't work on p4m266a mother board
The hard disk maybe faulty especially if the BIOS cannot detect the hard disk.
Try connecting the hard disk into an USB hard drive adapter and then plug it into the USB port of a working computer. If this computer cannot detect the USB hard drive adapter as an external storage device then this hard drive is faulty.
Oct 29, 2012 | Computers & Internet
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
A disk read error occured press control+ alt+delete to restart
The hard disk may just need reseating or it may be faulty.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the computer and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
May 06, 2011 | Computers & Internet
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
MY WD can't recognize by my pc but last week i use it but there no problem but when i plug it again today in my pc the book are not be read and theres no icon that can be seen in the HARD DISK DRIVERS BUT...
Device Manager only says that the disk is getting AC power, and that the "data" cable is connected, and that Windows has recognized the specific device-information (that it is a disk-drive, and that the capacity of the disk-drive has been recognized).
Device Manager does not say that the "spinning" part of the disk-drive is still spinning, nor that there are any I/O errors (trying writing with a pen onto greased paper -- not everything you write can be read).
Try connecting the MyBook to a different USB port on your computer.
Try connecting the MyBook to a different computer.
If it still is not "readable", then you have a few options:
* if the warranty still is valid, exercise the warranty, to get it repaired/replaced,
* disassemble the case, disconnect the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a "slave" drive in some desktop computer, to see if the USB-to-disk-drive adapter has failed
* buy a replacement disk-drive, connect it to that USB-to-disk-drive adapter, and close the case, to create a "new" external disk-drive.
Oct 24, 2010 | Western Digital My Book Essential 1TB...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Try a different USB cable.
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
Doesnt register and all the lights stay
Does it work after you change the USB cable?
If so, then your USB cable is the problem.
Does it work on some "other" computer?
If so, then your computer is the problem.
Does it work it _any_ USB port in your computer?
Failing that, disassemble the casing, to find:
* the USB-to-disk-drive adapter,
* the disk-drive itself.
Connect the disk-drive as a "slave" drive to a desktop computer, to see if the disk-drive can be detected.
If not, then the disk-drive has "died".
Buy a new disk-drive, and connect it to that USB-to-disk-drive adapter, to "revive" your external unit.
Read the serial-number from the disk-drive, and access Western Digital's web-site, and enter the number in the "check warranty" section, to see if your unit is still under warranty, i.e., a free replacement.
If not under warranty, then W.D. has a "Customer Loyalty Program" -- buy a new External Hard-Drive from their web-site, and they will give you about a 20% discount from their "retail" price.
Apr 08, 2010 | Western Digital Passport 320GB External...
Mhy maxtor external hard drive is not being recognized by my computer. What do I need to do?
Does it work when connected to a different computer?
If not, is it still under warranty?
If not, disassemble the case, and you'll find an "internal" MAXTOR disk-drive inside the case; try connecting that drive as a "slave" disk-drive inside your computer. If it is not recognized, then it is "dead" and you should take a hammer to it, so that any of your personal data on it will become impossible for any "identity-thief" to read, and then buy a new, larger, external drive.
Sep 13, 2009 | Maxtor Hard Drive
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
890 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
