Question about Minolta EP1030/1030F CS/PRO Copier
My minolta error code says J3, which has something to do with the flags. How do I reinstall the plastic flags?
The machine will turn on but that is it. It won't even humor the idea of making a copy.
  • Minolta Master
  • 1,297 Answers
Verify the exit part actuator,is damaged,J 3 paper jam in exit section.The exit actuator is located after fuser unit.
Posted on Mar 04, 2013
  • 87 Answers
SOURCE: Minolta CS PRO black/white copier has error code
COF30 THIS CODE SHOWS THAT THERE IS PROBLEM IN AUTO TONER SENSOR.MAY BE IT IS DIRTY .CLEAN IT PROPERLY .OR REPLACE IT.PROBLEM WILL BI REMOVED.DO NOT FORGET TO RATE A SOLUTION.MIAN JEE
Posted on Feb 22, 2009
firecontrol7
  • 6763 Answers
SOURCE: Machine makes a loud wheezing noise just before
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 02, 2009
FixinFax
  • 3085 Answers
SOURCE: error code AP Minolta (old) copy machine
AP=add powder. It's low on toner.
Posted on Feb 16, 2010
  • 10 Answers
SOURCE: cannot find fix to j3 error code minolta 2150
remove misfedd paper
Posted on Feb 13, 2011
  • 20 Answers
SOURCE: My minolta 1083 is making black copies ,The drum
you need to clean out the drum unit of waste toner than probably have to replace the cleaner blade.
Also check to see if there is a tension spring employed to add friction(since this is a phase - out model, I'm guessing there is), you might have to modify this spring to add tension to the cleaning blade support plate.
Posted on Feb 23, 2011
Minolta di450 how i can solve this code c-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta Office Equipment & Supplies
Installed new toner cartridge into the machine. Still getting the J3 error
Toner cartridge and J3 are two different things J3 is jam code something is not correct in the paper path.
Nov 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
Konica minolta 363 error message c-2201
remove the toner bottle reinstall when machine ask for it.
Feb 24, 2012 | Minolta Office Equipment & Supplies
Code. 70
Error code C70 means the toner bottle is not turning correctly. Did you just install a new Toner??? If so, take the toner bottle out carfully and close the door and let the copier warm up to "READY" reinstall the toner bottle and see what happens... It may also be a defective bottle. If the problem is still there, you may have a problem with the hopper unit & the "HP" flag & sensor. Good Luck
Sep 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
KONICA MINOLTA C253 COLOUR MACHINE ERROR CODE C-D403 touch screen not working printout not coming our service engineer could not find the error
The c-d403 code indicates a checksum error. Try turning the copier off and on via the Main power switch either behind the copier or inside the front door of the copier. Checksum error along with no operation panel means something could be fried on the main board.
Feb 17, 2011 | Konica Minolta bizhub C250 All-In-One...
Error code j3 for ep 1030
j3 - exit jam
search for a lever at the exit point of the copier, you sould be able to see the sensor at the lower part of the fuser. I may bejamed or the flag broken.
Nov 12, 2010 | Minolta EP1030/1030F CS/PRO Copier
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
57 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
