Question about Dell Inspiron B130 Notebook
High Pitch noise from my B130
When My Dell B130 Notebook cover is on, but the cover is closed, I hear a high pitched intermittent noise. The only way to stop it is to turn the power off.
I just replaced the battery with a new one... and I have the same problem.
Anyone know about this problem???
  • Dan rogers
    Dan rogers May 11, 2010
    So is the sound coming from the battery?
    President:
  • 2,653 Answers
Sounds like a hardware problem, but it could be software.
What happens when you mute the volume?
Does it sound like its coming out of the speakers or somewhere else?
Posted on Feb 20, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
High pitch intermittent noise
Check your fan and clean it up
Sep 08, 2014 | Samsung RF4287HA
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
High pitch noise from the flyback
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Jan 23, 2009 | Samsung HL-P6163W 61" TV
High Pitch Noise in 2000 Jeep Grand Cherokee limited
Check your power steering fluid level, and system for leaks. May be a bad p/s pump as well. Hope this helps
Nov 29, 2008 | 2000 Jeep Grand Cherokee
FUEL STARVATION
need to change a new pump.
Nov 12, 2008 | 2002 Land Rover Discovery Series II
High pitched squeal
What an RCA I hope you didn't pay mutch for this, NO it's not the part of the board were the cable goes in, the so call squeal is the horizontal oscilation of the coil you hear, narmaly it is at the rate of 15747 hz, to find your problem you most open the back cover, and while the ptv is on try to hear by insolating the noise were it is comming from with a credit car or something that will hide the section you trying to find, it will be a transformer or a coil, close to the power supply or the horizontal defflection section. To fix your problem well that's all a different game, you must contact me via e mail at rlandry@vianet.ca
I hope this help.
Meanwhile keep on smilling, life to short
What about Bob
Bob
Timmins, Ontario
Feb 24, 2008 | RCA P46921 46" Rear Projection Television
Dell Inspiron B130 Notebook Logo
135 people viewed this question
Alun Cox
