Question about Microsoft Xbox 360 Console
3 flashing red
3 red lights flashing and power supply is on green ...
  • 77 Answers
You have the dreaded Red Ring of Death. IF you contact Microsoft at www.xbox.com, they have extended their warranty regarding this issue to 3 years. They will send you a return shipper and cover postage both ways if you ask them to as well. This will be repaired at no cost to you.
Posted on Feb 20, 2009
2 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: 3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Posted on Aug 03, 2009
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Power on then 3 red light flashes
your console is nto connected to tv properly, unplug all cables and set up again.
Mar 14, 2010 | Microsoft Xbox 360 Console
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
Aug 03, 2009 | Microsoft Xbox 360 Console
3 red flashing lights
When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply is button is red than you need to replace the battery or check the connections.
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. If you are experiencing this problem, you can submit a console-repair request online.
Hopefully your system is still under warranty.
For step by step troubleshooting directions please read the attached link and Happy Gaming!
http://support.microsoft.com/kb/907534
Oct 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
