Question about Frigidaire FEF365AS Electric Kitchen Range
The broiler works but the self-cleaning and baking does not on my Frigidaire ( model# FEF365BWG )oven.
  • Frigidaire Master
  • 3,361 Answers
Remove the rear panel and ohm the thermal fuse for continuity.
If bad replace it.
P.S. Do not use the self clean feature on ovens. It is detrimental to continued operation.
Posted on Feb 21, 2009
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Model FGF366BCA range Problem: Baking function & oven cleaning function stopped working, (broiler works fine).
I used the self clean feature on mine and found that it got so hot that it burned out the sensor and ended up with the same symptoms you are describing. Had to have the sensor replaced. DO NOT USE THE SELF CLEAN
Mar 11, 2011 | Ovens
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a GE XL44 gas range. My Broiler goes on then off, on then off what could it be?
if this is a self cleaning model with the broiler at the top of the oven then i would guess that you may have an ignitor going out. is the bake working ok?
if this is not a self cleaning model and the broiler pan is underneath the oven then it uses the same burner as the bake. if this is the case you should also be having trouble with the bake function.
May 28, 2010 | GE Kitchen Ranges
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire single oven(model # FEF365BWG) broiler works but the baking element does not work.
the element needs to be replaced as its not getting proper current because its got cut in between.many a times cleaning the element and refitting it again makes the device working.
Feb 20, 2009 | Frigidaire FEF365AS Electric Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My oven does not work but broiler does
Look at the ignitor. Should have 110 volts to it when on bake. Replace if not glowing. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 27 in. Electric Double...
Frigidaire FEF365AS Electric Kitchen Range Logo
229 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
