Question about Honeywell HCM530 Humidifier
Skuttle Drum Humidifier Noise
I have a Skuttle Drum Humidifier, Model 190, that operates by a humidistat. There is noise coming from inside the motor cover. It constantly wines when the humidifier is on.
5 Suggested Answers
Joe_Rex
  • 114 Answers
SOURCE: Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Posted on Apr 28, 2007
  • 8 Answers
SOURCE: Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Posted on Feb 04, 2009
  • 232 Answers
SOURCE: Testing a Aprilaire Humidifier 600 Controller
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Posted on Dec 31, 2009
SOURCE: Vicks v4500 humidifier stopped working.
i know why. clean the small long tubular thing that is sucking the water. put a q tip in there and get the gunk out. thats what you need to do -- try it and let me know if it worked. msoobhawan@gmail.com it worked for me!
Posted on Feb 06, 2010
I have a skuttle 45sh1 humidifier that i just replaced the humidistat. when i went to turn it on, nothing happened.
Possibly new part is faulty. Check by removing both wires and tape together if you don't have a volt-ohm meter. Unplug unit before removing wires. it should run. If not, return part and exchange for a new one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 31, 2017 | Skuttle Humidifiers
How do I wire up a Honeywell HE120 so it gets power only when the blower is on?
You didn't say what kind of furnace you have, but here is a link to what is known as an "air flow" switch that will allow the humidifier to operate only when it senses air flow through the furnace:
http://www.alpinehomeair.com/viewproduct.cfm?productID=453057513
Jan 26, 2015 | Honeywell HE120 Humidifier
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
My furnace is about 5 years old and the humidifier(skuttle190) has not been used in several years. I just ordered a new filter as the present one that I have does not fit properly on the wheel, its too...
Hello, if this is a drum type humidifier the small motor that turns the drum might be bad, take the drum off and see if the small shaft of the motor turn without the drum on it. if it does not turn than most likey the shaft or the internal parts of the motor are craked and must be replaced. If it does turn without the drum on it than either the filter is causing the problem or the drum is not seated properly. I hope this helps
Feb 13, 2011 | Skuttle 190 Humidifier
I have a Carrier humidifier model #HUMCCLBP2217-A. It appears to be working, but every time it shuts off it emits a very loud "thump". The noise is loud enough to wake me up at night. I have...
Do you feel like looking at the humidifier yourself?
You can open the door on the unit, while the furnace is running--
The humidifier is usually installed in the return air duct, so there will be a sucking of air into the open door, when you open it.
There is usually a large wheel, with a wet pad wrapped around the circumference.
This wheel rotates slowly, and picks up water from the sump-- does everything look and sound quiet as it runs? -- The float valve has to open and close, to c ontrol the leve of water in the sump-- (The pool of water the wheel runs the mat thru--
Possibly the valve shutting off, could make a plumbing BANG-- you could duplicate that, by lifting the float mechanism and stopping the water-- does that make the noise?
If you can reach and operate the Humidistat control from near the humidifier, do so a few time-- or Have someone cycle the humidistat a few times, and you listen for that sound--
Is it in the humidifier itself, or the duct work nearby?
It might be that the humidistat wheel scrapes against the side of the sheet metal duct work? -- Sounds travel a long ways in metal duct work!
Let us know if this helps
Mack B
Jan 19, 2011 | Carrier SBP Humidifier
When the humidifier set to above 25%, there is a periodically repeated loude noise. when the setting is lower than that, the noise is gone. please let me know what is the problem.Tthank you
It sounds like the little wheel that rotates the wet pad, is rubbing, or jammed or what?
Open the door on the return air duct, near the furnace-- See the wheel inside?--
Raise the Humidistat-- can you see the wheel begin to rotate?
Maybe you hear the noise more plainly now-- can you see where the noise is coming from?
While you are in there-- can you see the pad?-- does it look like it should be replaced?-- When was the humidifier last serviced? -- You can get a new pad or two from your local hardware store-- and they should be replaced ever few months-- (or as needed) in the heating season..
Note: When you open the door, the fan will be sucking air into the opening--- that is alright-- you need to see the humidifier rotating, check the drive motor, the big wheel, and the water sump-- is the float working OK-- Not running over-- but keeping the sump filled just right-- You can bend the float arm to adjust the level..
Check it out, and let us know what you need or want to do next.
Mack B
Jan 18, 2011 | Aprilaire Humidifiers
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Loud "Glonk" when humidifier turns off
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Mar 12, 2008 | Aprilaire 700 Humidifier
Honeywell HCM530 Humidifier Logo
97 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
