Question about Asrock 775i65G Motherboard
Power supply aux power connection burned out
I have a 775i65g motherboard, and the 4 pin aux plug on the power supply that connection to the motherboard get hot and melts, it may take a day or a few hours before it does that, this has happened with three power supplies, can you help me solve this problem, or should I buy a new motherboard?
    President:
  • 2,992 Answers
If this happened on three supplies, the trouble has to be in the motherboard connector. Probably one of the pins is corroded or very loose and causing a poor connection. The resulting heat is melting those connectors. You would be best off replacing the board since you don't know if other problems may be waiting to occur. A replacement would probably cost around $50 to $60.
Posted on Feb 20, 2009
M3A770DE 4 pin
Due to the 'large expanse' of information you posted I can barely contain myself.
1) 4-pin ATX +12 Volt power cable, that plugs into the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Note that this power cable has TWO Yellow 12 Volt wires.
Back in the day there was no additional power cable needed, for the motherboard.
When the Intel Pentium 4 came out, the 4-pin ATX +12 Volt power cable came out also.
Power for the Processor.
More, and more powerful hardware components for the motherboard, (Processor and graphics card), required more power to the motherboard.
The 6-pin PCI Express power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
This power cable was used to connect directly to a graphics card, and provide power to it.
Note that this power cable has THREE Yellow 12 Volt wires.
It can carry up to 75 Watts of power.
Still wasn't enough power TO the motherboard, and TO the graphics card, with the new hardware component technology being brought out.
The 8-pin EPS +12 Volt power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
Note that this power cable has FOUR Yellow 12 Volt wires.
Is capable of providing up to 150 Watts.
A PCI Express x16 slot is capable of providing 75 Watts.
Note the shape of the sockets in the connector.
Now compare to an 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
DO NOT confuse the 8-pin EPS +12 Volt power cable, with the 8-pin PCI Express power cable.
They are NOT the same.
The 8-pin EPS +12 Volt power cable's connector on the motherboard, is at the top left corner of the Processor socket, and close to the outside edge of the motherboard.
(With motherboard installed in computer case)
You can use the motherboard with just a 4-pin ATX +12 Volt power cable.
Look at the LOCK on the side of the 8-pin EPS +12 Volt power cable's connector.
With that Lock AWAY from you, or on the opposite side of the connector, a 4-pin ATX +12 Volt power cable plugs in on the RIGHT side.
If you have a powerful graphics card installed in your
PCI Express x16 -> slot/S, you had definitely better use a Power Supply that has an 8-pin EPS +12 Volt power cable.
This is a 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Misnomered as a 'Molex' power cable.
{ Molex was the first to design and produce this style of power cable CONNECTOR. The name stuck. Kind of like calling an open-end wrench a Crescent wrench }
IF you use an adapter power cable; Use TWO 4-pin standard Peripheral power cables!!
You need those Yellow 12 Volt wires.
What will happen if you do not use two?
1) The PCI Express x16 slot/s will burn.
2) The gold plated contact pins on the PCI Express graphics card, or cards, will burn.
3) If the graphics card, or graphics cards, require a power cable connected to them;
A) The connections on the graphics card for the power cable will burn.
B) The power cable connector will burn.
Other than that the only other 4-pin references on the motherboard, that I can see, is the optical drive's 4-pin audio cable connector on the motherboard, (CD1), and the CPU (Processor) Fan 4-pin connector on the motherboard.
For additional questions, or if the above is not what you seek, post in a Comment.
Regards,
joecoolvette
Oct 08, 2012 | Asrock M3A770DE ATX AM3 AMD770 DDR3...
I have tried running 2 different M4A79 deluxe motherboards with a corsair 650W power supply, phenom I X4 processor, and an nVidia 9800GT video card but neither of them will so much as turn on with...
It sounds like the ATX power supply is not getting turned on by the motherboard.
In order for this to happen, pin 14 (PS_ON*) of the 20-pin ATX power plug from the power supply must be pulled to ground. You can test this by plugging the power supply in to AC power without it plugged in to the motherboard.
Using a paper clip, short pin 14 (PS_ON*) to pin 15 (ground) and the power supply should turn ON.
Looking at the front of the 20-pin plug, with the latch on the top, pin 14 is the 4th from the left
__
_________________' '________________
' 11 ' 12 ' 13 ' 14 ' 15 ' 16 ' 17 ' 18 ' 19 ' 20 '
' 1 ' 2 ' 3 ' 4 ' 5 ' 6 ' 7 ' 8 ' 9 ' 10 '
Front of 20-pin ATX Power Connector
If you can turn on the power supply by shorting pin 14 to ground, but it doesn't happen when plugged into the motherboard, there is most likely a jumper setting on the motherboard which has not been configured correctly.
I hope this helps!
Mar 13, 2011 | ASUS M4A79 Deluxe Motherboard
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
I have a mother board with 4+4 pin atx connection but the additio
The extra 4-pin connector should slide into the side of the larger connector. If the leads are the following: black/yellow/yellow/black, then this connector goes on a different location (usually close to the CPU/heatsink assy). Sometimes the PSU will not come equipped with the aux 4-pin that slides in next to the main connector... The computer generally WILL work without this connector, provided the aformentioned connector is connected in the aforementioned slot.
May 23, 2010 | Antec Basiq BP500U (ASKU51402) 500-Watt...
CPU overvolted and burn using 8pin eps12v cable on crosshair
no i dnt think so some time due to manufacturing defects this happens the new one wont burn unless and untill u over volt it.
Jan 31, 2010 | ASUS CROSSHAIR Motherboard
ATX Power Supply Question
Most new power supplies have a twenty pin Molex connector and a 4 pin Molex connector. If you look closely at the connectors you will see that they go together a certain way. It can be very hard to tell. Take a close look at the shapes of each terminal. Match them up exactly.
Nov 28, 2008 | Gateway Computers & Internet
2 ATX POWER SUPPLY PLUGS
Some motherboard/cpu setups require an additional 4-pin connector for additional power on the motherboard. The motherboard will require either a 20-pin or a 24-pin power connector (main power), and might need the additional 4 pin as well. If the motherboard will accept the additional 4-pin, then connect it!
Sep 04, 2008 | Gateway GT4022 PC Desktop
Wont power up ecs motherboard
Your 4-pin power connector supplies voltage to your CPU through some series of MOSFET transistors. First try to disconnect your CPU from the socket and power up your motherboard. Your CPU might be toasted. MOSFET transistors might be bad. Also look at your big caps around the CPU. If they have bubbled tops, you need to replace them.
Good luck
NetSalem
Jul 17, 2008 | Intel Motherboard
Abit IP95 Mobo fails to power up.
Ok, try connecting just one thing at a time - start of with just your board and the power supply... still smell burning? There's probably an issue with the power supply - no fans & leds would indicate this too (can you hear anything when you power up?)
What cooling have you been using - weird quetion, but is there any chance there could be moisture on the board? (either from water cooling or from condensation in the room)
Feb 09, 2008 | Ziotek ATX Motherboard Standoff, 12 Pk...
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Asrock 775i65G Motherboard Logo
81 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
