Wheelwriter 3500 - I cannot type letters on paper but I do see the letter on LCD screen.. On the LCD screen it says "DL PRT". What does this mean and how do I remove it? HELP!!
Hold down the "code" key, the one to the left of the spacebar that says "CODE" on it, and hit the "L" key (the one that says (Lang) on it. Should be back to normal.
If it types as you press the kets delay print is turned off, press the print mode key on the r R. side until Dl prt is on the display. If it just starts typing at a the same position every time you probably have the R. margin set there and auto return on (CODE R).
I'M assuming this is a wheelwriter 30 or similar. On the R. side of the keyboard is a key that says print mode press that and the dl prt will go off on the display. If you are only printing the tops of the letters the platen is probably not fully seated in the side frames press down firmly on both ends it should snap into place.
Check the connectors from thr PC board to the keyboard, if they are OK tren try this hold the code key press and release the "L" key type 001 release thecode key. If this works you need a keyboard to repair it'
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
