Question about HP (122226-001) Fan Controllers
Computer constantly running without specific guidelines
I can hear the computer running what appears to be a scan but nothing is scheduled. How do I find out what is happening?
    Scholar:
  • 60 Answers
Press and hold down the "Ctrl" "Alt" and "Delete" keys. The Windows Task Manager window will open up. Click on the "Processes" tab. Click on the "CPU" heading two times. You are now looking at what is using up the most CPU cycles. Hopefully "System Idle Process" is at the top of the list. As I type this out my System Idle Process is bouncing between 95% and 98% as it should. You can use the "End Process" button in the lower right corner to end whatever process is curently highlighted. If you do you will get a warning about the horrible consequences of doing this but more often than not you can ignore that message. If you don't know what the process is, Google it. Hope this helps.
Posted on Feb 21, 2009
  • benkool Sep 30, 2010
    When laptop battery went bad, the power meter program running under system will cause 60% to 70% CPU usage. The task manager can only show System is running with 60%~70%. After removing the battery from laptop with only AC power, system then became idle.
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Tip
How to tell your antivirus is fake?
Most of time, you use search Engine like Bing, Google, or Yahoo, and several links from top 10 of search results take you to another link and once you click on that link, ooops you receive pop up saying your system has infected. It will scan your system without of permission, and ask you to pay for activation for antivirus software. Use the following guideline to identity the fake one.
The antivirus that installed itself and proceed to scan is not a real one
If you are remind to pay for activation, it is fake
Real antivirus will scan your system, and download the latest definition file on scheduled. Real one won't bother you. On the other hand, fake one used annoying alerts to alert you.
Keep these guidelines in mind to identify the fake and not paying for any activation.
on May 11, 2011 | Computers & Internet
What is the solution to "Exception EOleSysError module at 00058E75."
Try this:
Run a CheckDisk:
How to run Chkdsk at the command prompt
(Windows XP)
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
      Windows Vista & Windows 7
      You can launch CHKDSK using two methods (the former being the easiest):
      Graphical Interface:
      Open the Computer option from the start menu, which will display all of the drives available to scan on your PC:
      Then, right click on the drive you wish to scan for errors and select Properties:
      Now click the Tools menu, then Check Now under the error-checking section:
      You have several options within the check disk tool. It is always recommended you leave the "automatically fix file system errors" box checked, as this repairs and problems found. If you want to perform a deeper scan, tick "scan for and attempt recovery of bad sectors". This second option takes longer, but is worth doing if you suspect a drive problem. Once you are configured, click Start:
      If you try to check a disk that is currently in use, you will receive a message asking if you wish to schedule a scan. Accepting this will perform the scan next time you restart your PC:
      Good Luck!
Aug 17, 2012 | Computers & Internet
Constant lockups in bios or os
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this task will schedule when computer restarts which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive do nothing while the chkdsk utility ani input may damage your computer then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them they could be faulty
hope this helps
Jun 07, 2011 | SuperMicro Server Board X7DCAI...
Ihave amercury pi945gcm please till me how can I dellete the information appears on the screen when I turn my computer on and makes my computer turns on without showing the features of the the main...
if the imformation are desktop icons(short cuts) right click on them select delete
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope this helps
May 08, 2011 | Mercury Computers & Internet
My laptop freez some time mouse and keboard nothing wor i have to switch off laptop and on again tell work
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
Jan 19, 2011 | Fujitsu Fujistu ST1200 Notebook
Booting problem.....
if you still having booting problems, you can do this suggested steps:
Insert the Operating System CD before pc reboot
Try to boot to safe mode with command prompt by pressing F8 repeatedly , select "safe mode with command prompt " option then hit ENTER, then run this command ...
Then follow these guidelines:
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
Hope this help...
Apr 18, 2010 | Lenovo IdeaPad Y510 Notebook
Laptop is running but screen constant black
it seems the sudden loss of power fried the screen...or it could be the video card that might have downed.  always try to use keyboard combos like crtrl+alt+del or alt F4 before resorting to such violent measures :(
Feb 04, 2009 | Everex StepNote VA4300M Notebook PC
HP 5610 scanner won't save image
I just need to understand the exact issue. It sounds like you are able to successfully scan, see the preview of the scanned image, and you initially save it. Then, when you go to open the saved image, you don't see the image you scanned but rather a "line". You've saved the image in a number of different image formats, but there's no difference in the result. It saves the scanned image to the location you want to save it on your computer's hard drive (probably My Pictures if you're using a Windows operating system).
Not sure what you mean by a "line". Do you mean a vertical line, a horizontal line, a diagonal line or what? Also, is it just a solid black line on a white background? Is it the image you scanned compressed into a smaller vertical or horizontal space?
Have to tried scanning both text pages and graphic pages? There have been issues where a document with both text and pictures has been scanned but when the scanned image is viewed, only the text appears. The pictures don't make it. The description of this specific problem is at HP.com.
I take it you don't get any sort of error message associated with this problem. Unfortunately, I can't find your specific problem at HP.com beyond the link I posted in the above paragraph. If you can answer some of the questions I asked, it might help me provide a better solution.
Thanks.
Sep 25, 2008 | HP Officejet 5610 All-In-One InkJet...
My Norton Security System independently decides to run its security scans automatically around 8pm most every night. I run an eBay business and this is PRIME TIME for me. It's putting me out-of-business....
1 Start Norton AntiVirus. If Norton AntiVirus is installed as part of Norton Internet Security or Norton SystemWorks, then start that program. 3 Click Configure a Scan, and then click Schedule Full System Scan. 4 Fill in the Schedule Task, Start time, and Schedule Task yourtask fields. 5 Click OK.Hope it can help you.
Jul 30, 2008 | Computers & Internet
HP (122226-001) Fan Controllers Logo
327 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
