Question about Philips DVP5990 DVD Player
I was told that this model DVP5990 read french dvd
How do I get the multizone codes and do I proceed to enter them
  • 814 Answers
Power on the dvd player and with no dvd or cd in the dvd player, Press the setup key on the remote control. This will put you in the set-up menu. Use the up and down arrows to find the preference section. Highlight it and press ok and then press these number keys in this order. The region sub-menu will appear. On the region sub-menu use the up and down arrows to select the (0) region, Press ok. This will make the dvd player region free. Now press the setup button again to exit the set-up menu.I hope this information help you with your problem.
Posted on Jun 02, 2009
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
Is there a way to change the region code for a samsung dvd-V3650?
Hiu this code for DVD-3250, it may work for you.
1) remove disc and wait for "no disc" to be displayed
2) press "pause,, 3,1,4,1,5,9", Code-- will display.
3) enter code for region using numeric keypad( 09 may work for multizone).
4) press "pause, power"
alternatively DVD -V440
1) step 1 above
2) press"subtitle,7,6,8,8,4" then "9 (multizone), subtitle"
3) open & close drawer
Good luck
Mar 17, 2010 | Samsung DVD-V3650 DVD Player/VCR
Codes to make philips soundbar hts 8140/75 mulitzone
I followed another post which is a generic code for all philips dvd players. open the dvd drawer, push, close drawer. done! terrific
Jun 05, 2009 | Philips DVP5990 DVD Player
I found it somewhere in the Net, and it worked in my case:
1. Turn on the player from the front panel (without a CD/DVD inserted!)
2. Select HOME on the remote and ensure Hard Disk is highlighted
3. Press PLAY
4. Immediately enter 159 121 212 005 255
5. Press PLAY
6. Turn the player off
When you turn it on again, it is multi-regional!
Nov 15, 2008 | Philips (MCD700) System
To convert to multizone toshiba sd-290
1) Connect to TV
2) Power on DVD
3) Enter 7777 using remote
4) Use on-screen menu to change region code (region code 0 = region-code free)
5) Power off DVD
The DVD is now region code free.
Jul 29, 2008 | Toshiba Televison & Video
Unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
  1. Open the disc door
  2. Press Setup, Vol +, Vol -, Vol +, Vol - on the remote control
  3. Press < or > on the remote control to select the region code (255 is all regions)
  4. Press 'enter' to confirm
  5. Close disc tray
Hope this helps.
Jun 12, 2008 | Televison & Video
Multizone code
icon_minipost.gifRegion code hack posted by Tiger1, May 24 2007:
Hi I live in Australia and added this model.
acknowledging: Region code hack posted by ZoidsGodzilla, November 22 2006: for the Samsung DVD-V5600
1. Press the DVD button on your remote (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the usa ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 129334
Have Fun :0)
Mar 25, 2008 | Samsung DVD-V6700 DVD Player/VCR
TEAC PL-D33200
Multizone code for Teac PL-D3200
Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Jan 20, 2008 | JVC TH-S8 System
Philips DVP5990 DVD Player Logo
206 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
