Question about Car Audio & Video
Car radio wont work
My non stock radio in my 1990 ford probe wont work it has power but doesnt work other than that it worked fine when we got the car but then we found a red wire disconnected on the drivers side floor and ever since then the radio hasnt worked if i could figure out where the wire goes i could fix it but i have no idea i don't have a diagram of my cars electrical
  • 55 Answers
If you Have Display Lights.Then the Memory wire is Hooked up .But the Power wire is not.That is the Red Wire Hanging.It was going to the fuse box before it fell off .Use a Volt Meter (DC).Or a12 volt test light
You Want a Fuse that only has Power (12 Volts) When the Key is Turned on.Use a little connector to connect the wire to that fuse...That will do it..Good Luck
Posted on Feb 20, 2009
Car radio has no power
This could be due to a poor power connection - maybe a bad splice or something that loosens periodically.
Nov 27, 2013 | 1990 Ford Probe
Would shut off for no reason, then finally will stopped at a convenience store went to start to drive off, would not start. After many attempts and replacing various parts car still is sitting, no spark...
I pulled up to a convenience store and my 1990 ford probe died and had no power to anything, It ended up being 80 amp fuse under hood main fuse bolted in black with clear top, changed it worked fine after that. hope this helps
Sep 07, 2010 | 1990 Ford Probe
How to install into my 1993 ford probe?
Here are the factory wiring colors match these to the aftermarket names (12v to 12v Ign - Ign, etc)
1993 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
May 26, 2009 | Car Audio & Video
1989 to 1990 Powered door conversion
about the only advice i can give is that i did the same thing with a 94 probe base and a 94 gt. i had to take the whole wiring harness out of the gt and put it in the base. It starts from the inside fuse block, goes to both doors, under the front seats, all the way to the fuel pump, abs, tail lights, and pretty much everything from the dash to the rear of the car. If you can get a whole harness, it should work.
Mar 09, 2009 | 1990 Ford Probe
1991 ford probe
duck tape on the air intake. I just fixed mine. There is a crack on the intake that lets too much air in when you put it in drive that makes the car stall. Try it it works.
Nov 23, 2008 | 1990 Ford Probe
Transmission stops working when hot
You are probably having ATF bubbles flowing through your tranny either from overfill or by using cheap ATF / the wrong atf. Consider a drain and refill 3 times (driving for 5 minutes in between a drain and refill. This time only use dealship ATF and I guarantee you the problem will go away.
Nov 12, 2008 | 1996 Ford Probe
1990 ford probe won't start
ignition relay or fuel pump relay that is all I recall working on those years back good luck hope that helps you!
Sep 23, 2008 | 1990 Ford Probe
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
