Tommy, I have a 2232GW Monitor that just started flickering when I siqn on. It started getting slower each time. I started leaving the computer on to avoid the delay. Then it started flickering,blinking again. I turned it off, an now it won't come on at all? It's a Samsung only about 7 months old.
  • xcvbnmz Feb 20, 2009
    i cant turn it off
  • mrtimsmith Feb 20, 2009
    It would not turn off either. Do you have any repair souution???????
Veiwsonic VP2365wb backlight flickering
If it's not under warranty, buy a new one from newegg dot com.
Mar 27, 2013 | ViewSonic VP2365WB 23 inch LCD Monitor
Acer AL22 Has no image for 1 Hour. Then is OK.
That is a common symptom of a failing power supply board. The filter capacitors start to go bad and the power supply can not stabilize and start correctly, after the capacitors are powered up for a while they can hold a charge and the power supply finally gets going. Here is a link to a repair guide for that model.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
Oct 26, 2012 | Acer AL2216WBD LCD Monitor
My 2232gw started flashing, as if the starter is
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Backlight is acting like a bad flour. tube .. everthing else OK
Normaly the backlights have a life of around 40k hours of working.
If your monitor is 3-4 years ,the backlight tube/s could be defective.Your description seems to indicate tube aging.
It's possible to replace the tube but needs a good amount of technical skill.
Do write if you need more help,Please indicate make exact model no etc.
Samir
Mar 22, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor is failing to start although power is on
Sounds like you've got some blown capacitors on the internal hardware of the monitor.
Unless you are a seasoned computer hardware expert or electrical engineer I'd recommend you replace the monitor.
The capacitors that are blown are likely controlling the power aspect of your monitor, and aren't totally defective yet.
Most computer shops would not be able to repair your issue, due to lack of skills related to monitor repair. So you're going to find replacement the easiest / cheapest solution.
Of course you can try to ride out the problem as long as you can. But it will get worse over time.
Jan 08, 2008 | Xerox XA7-192i 19" LCD Monitor
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Computers & Internet Logo
722 people viewed this question
David Payne
David Payne
