Question about Dell Inspiron E1505 Notebook
Windows wants to start but...
I turn on my computer its a dell labtop windows 98 screen appears then the white line at the bottom then the screen goes black then says set up is being restarted then back comes the black screen can you please help me its drivng me crazy
    Problem Solver:
  • 19 Answers
Try to reinstall the OS.. ths will solve the problem...
Posted on Feb 21, 2009
Hello my problem is when i use my labtop dell vostro 1015 for 2 hours or less or longer than that it being freezing and stucked so in this case i shutdown my labtop directly from the on\off bottom and...
If it freezes very often then try to run a diagnostics on the system.. U can do it by turning on the computer, tap F12 - under advanced boot options select diagnostics and run a complete test.. If you get any error codes then contact dell to fix the issue.. If you dont get any error codes then try to clean the computer by doing disk clean up... If it still hangs then do a complete reinstall of OS.. If you dont have a disk then Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way
Sep 16, 2010 | Dell Vostro 1015 Laptop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dell Latitude 620 has problem with screen .. static lines appear and upper right hand corner goes white or black
Sounds like your screen is taking a poop! Either that or the ribbon that goes to the screen is wearing out. Take to local pc repair shop.
Mar 29, 2010 | Dell Latitude D620 Notebook
Black and white lines after bios screen before boot up
The issue appears to be cosmetic if the system boots to WIndows and there are no display issues using the system. Some systems I've seen have a bit of video distortion between the BIOS splash screen and the desktop. A couple things may change that. Update the system BIOS and the video driver to the most current available
May 23, 2009 | Dell Latitude D610 Notebook
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Red vertical lines appear, can only run computer in Safe Mode
check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Aug 27, 2007 | Dell Latitude C640 Notebook
Dell Inspiron E1505 Notebook Logo
99 people viewed this question
Alun Cox
