Question about HP PSC 2210 All-In-One InkJet Printer
Self-test issue with HP psc 2210 all-in-one
When i turn the HP psc 2210 on, it makes the self-test & then its on normally but the scanner starts to make noises forever until i switch it off .. i took it for the agency on the warranty and they shockley told me throw it & buy a new one !!!!!!!!!!!! .. oh my god .. i was shocked when i even listened to the customers attacking me too as if i was totally wrong to bring it to be fixed on the warranty .. i won't be shocked if i found a big sign outside my house "BUY A NEW PRINTER - NO WARRANTY FOR YOU" .. :-)
anyway, please help me fix it .. i don't know if i can update the firmware or something .. ?? .. any solutions ?? .. thanx in advance..
    Genius:
  • 2,120 Answers
No fix, a new scanner will cost as much as a new machine IF you could find a new scanner assy
Posted on Feb 21, 2009
SCANNER FAILURE
The issue is with hardware of the printer.
Scan feature is most expensive and sensitive part of the printer.
I suggest you to contact HP support. If the printer is under warranty you may get a replacement printer or else they may give you a better option.
If not on warranty you may try this workaround:
  1. With unit off, press the 'Cancel' (pink button) and 'Color' (green button).
  2. This will start the printer in a diagnostic mode. Press '1' to run the diagnostics.
  3. Press 'Enter' or other keys as directed by the display prompts. When you don't know what to press, the 'Enter' key usually works. Some of the keys called for (for example 'Plus' and 'Minus') are not on every psc 2210 keyboard. They are mapped to one of the "directional" keys just above the numeric keypad area next to the 'Enter' key. Keep trying keys till one works.
  4. After all the diagnostics, the display will either go blank or display 'Initializing...' . Wait 10-20 seconds to make sure it isn't doing anything else then press the 'On' key.
The printer should start without the scanner error and the grinding/chattering noise.
Leave the printer on because the next power cycle brings the chattering noise back.
But, when it does, the procedure above seems to fix it every time.
PSC 2210 scanner failure HP Enterprise Business Community
Feb 18, 2014 | HP PSC 2210 All-In-One InkJet Printer
May be no ink; how can I check the cartridge have ink or not? and how can I change the cartridges?
Test cartridges first.
Press 1
press 5
this selects - self test
press start black or start color
this link will take you to hp and a pdf version of the owners manual.
http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Feb 26, 2011 | HP PSC 2210 All-In-One InkJet Printer
HP Psc 2210 powers up for around 5 secs then switches off
Unplug both ends of the power cord and count for about 60 seconds. Then plug back in. See if that works. That's what HP told me when I called customer service.
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
My printer will not print any documents, it does print a test page, when I select print the paper is ejected. I have re installed the software.
Try to print a self test page from the printer directly using the below steps....
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the front panel of the product.
  3. Press 1 , to select Print Report , then 5 , to select Self Test .After you have the report printed, check for 4 horizontal color bars in that report, the first color should be the the black one, if the black one is missing, issue seems to be with black cartridge, that may be the reason the printer spits out blank paper, try to replace the black cartridge and then copy if it copies or not.
Sep 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp1200 every time print self text page
after the test page plz put the test page in the scanner and push the scanner button
Jun 30, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP 2210 scanner self test problems
If the glass of your scanner is too close to the scanner array it can jam. The cure for this problem is to open the case and put some narrow strips paper under the glass. If under Guarantee take it back.
Doubt if you can bypass the self test.
Mar 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2110 all in one
Try to clear out all old print jobs and then go to your printer,
Right click on printer Icon and check to make sure it is set as Default.
Nov 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP psc 2210 printer
If you are able to print then there is no problem in printing.
Have you tried to scan, make sure if you are able to scan.
might be an issue with the scanner lamp.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 Scanner Doesn't Work
I'm not sure about this specific model, but I've had similar problems with other HP all-in-ones and usually what fixes it is uninstalling and reinstalling the software (make sure to follow their directions properly and not plug the printer in until they tell you to). You should also make sure you're using the most updated software from the HP website rather than the one that came on the CD with the printer which may be outdated.
Jan 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
161 people viewed this question
Seeker5211
Seeker5211
