Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
The internal display diplay of my pearl flip is fine but the external display show nothing when the flip is closed, no clock, no incomming calls nothing but the backlight
  • 2 more comments
  • rosestra Mar 08, 2009
    when someone calls me i cant see who is calling me unless i open the device
  • bigbreadman1 Mar 24, 2009
    The display shows nothing when closed
  • loveablematt Mar 28, 2009
    same thing nothing will show up on my external screen but the internal one works fine i cant see whos callin me or nothing unless i open the phone
  • Anonymous Apr 12, 2009
    outer display black no clock no nothing inner display is fine
I used to be able to see who was calling when my phone was closed. I don't know how it changed. However, I did what I think is called a 'hard reboot.' With the phone on I removed the back cover and the battery. I left the battery out for about 30 seconds. Then I replaced the battery and back cover and waited for the phone to restart. When the phone was powered up my setting was back to letting me see who was calling without opening my phone!
Posted on Apr 20, 2009
TRY RESETING PHONE SETTINGS THEN TRY AGAIN!
Posted on Feb 20, 2009
When someone is calling me my external display will not let me know who is calling
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Apr 16, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
When I get an incoming call it doesn't appear on the external screen until the call has ended so I can't see before answering who is calling me. And the screen with the number that's calling me and the...
When I try to delete my calls from the call log, there's a pop up that says uncaught exception and when I recieve a call the number does not show on the external screen until the call has ended and stays permantly on the screen....How do I fix these problems
Apr 15, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
My bb 8220 external display simply hangs once in 2-3 days. this usually happens when there's an incoming call, and it hangs with the caller id on display........gets resolved when you pull battery out and...
There is some virus in your phone... remove the storage card and then reset all the data.... you''ll contacts and messeges, so do note the essentials... now if the virus is removed then it will not create problem for you.....
Sep 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Jul 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
The external display on my blackberry pearl flip is empty
i had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Mar 05, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I tried resetting the phone setting, now T mobile is back on the external display. I would like T mobile be removed and relevant info. be displayed.
Go into the Application Loader in Desktop Manager and make sure that BlackBerry Attachment Services is loaded. That will restore your external display clock.
Feb 20, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Motorazor V3 External Display not working
hi racie,
1st i want to tell u that there are 2 types of diplay in flip mobiles like urs. and there are 2 display LCD plates/chips inside it.
One of the LCD plate/chip of the external display is damaged. It is due to hard flipping of the mobiles.
I recommend u to go to mobile technician coz it is a physical problem.
Looking for ur kind feedback,
Sajan (sajwhat_2003@yahoo.com / sajwhat@hotmail.com)
May 05, 2008 | Motorola Mobility RAZR V3
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
862 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
