If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
This skipping could be caused by a roller not turning causing the paper to be forced to much into the thermal.
Repair is quite difficult the unit would need to be taken apart and the feeder investigated. You could put some machine lube on the roller part, but its quite involved.
Another reason could be the module inside not working correctly causing it to print like it is.
If you update me with additional info I could be more of a help to you.
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration: If its a TLP2844. Load media. Connect power. Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration: If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute) Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
I can't seem to get the printer to work with Windows 7 - what can I do
