Question about Garland H283 Gas Kitchen Range
I have a Garland gas stove built around 1920. I need someone to tell me how to adjust the burners.
    Novelist:
  • 125 Answers
Hi there. When you say "adjust the burners", I am going to guess how to adjust the air setting? or are you looking for some other correction, problem fix, etc..
If you simply need to clean/adjust the air shutters, the easiest way to do this is, take the top grates off, now you should see your pilots, and the burner itself. You will lift the big end that is the burner, and carefully remove it off of the orifice on the valve you use to turn the burner on/off with. On the end that was over the orifice there will be a shutter that can get closed, clogged with dust, and affects the burner. set it about half way open, clean the dust out of it, and reassemble, that's it. If you are wanting something more, please comment. Thank you.
Posted on Feb 21, 2009
Can i convert a garland mod g286 stove from natural gas by installing apropane regulator
no
the modification from natural to propane or from propane to natural gas requires a jet change for all burners and an air flow shroud position change to get the correct blue flame ( correct air /fuel ratio)
it is a job for a gas fitter who will have the correct jets for each burner and will know how to adjust the shrouds
Jul 12, 2016 | Garland Kitchen Ranges
I have a 1920 Garland gas/wood stove that was running on nat gas and I want to convert to propane. Anyone know how this is done
To go from natural gas to propane you need to change the orffice where the gas feed comes out into burner. I the propane orifice feed hole is a different size.
You should be able to get this from a furnace contractor. They did this for me when I went back to natural gas.
Feb 25, 2015 | Garland Kitchen Ranges
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Garland oven does not work
Hi, it is hard to tell for sure, but it sounds like your safety device, the component that keeps the pilot lit, may have failed, allowing gas to the pilot, but not letting gas through to the burner. See your manual on/off valve lets gas to the thermostat, then through the thermostat down to the safety, because you wouldn't want gas to get past there if there is no pilot, and now that part is stuck open, but the rest of the part is not engaged to open and let gas continue to the burner. There is an easy way to tell, under the bottom panel, is a part with a red button ( the safety ) and connected to it is a copper looking tube, or the thermocouple, it can be disconnected by unscrewing it from the safety with a wrench, if the pilot goes out, your safety is mostly working, if not, it is bad, and needs replacement. Let me know, hope that help, and thank you.
Jan 05, 2009 | Garland H283 Gas Kitchen Range
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do...
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Dec 14, 2008 | Garland H283 Gas Kitchen Range
Burn marks on pot and pans
Just got a Garland 6 burner stove w/single oven. It was Natural gas need to convert to propane. Need supplier for conversion kit
Sep 05, 2008 | Garland H283 Gas Kitchen Range
Old garland H283 - need restoration
there is a place called barboys in farmingdale ny it has all the parts for the garland stove.
Jun 07, 2008 | Garland H283 Gas Kitchen Range
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
280 people viewed this question
Top Garland Kitchen Ranges Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
